Old 03-09-2001, 08:50 PM
slowbird's Avatar
slowbird slowbird is offline
How can I attach my 1/2 aluminum line to my steel braided hose. Is there a compression fitting that can be used. Please help I am stuck right now until I get this done.
slowbird's Avatar
Old 03-09-2001, 09:21 PM
TinInjun's Avatar
TinInjun TinInjun is offline
Location: American by birth, Southerner by the grace of God
Slowbird:
You need to get and AN818-8 nut and AN819-8 sleeve and flare the end of the tube with a 37 degree flaring tool(don't forget to install the nut and the sleeve first) Then get a AN815-8 union and you can attach the two together.
"Run wild with an Indian, not with the crowd in a Chevy"
Check out my restoration at http://members.aol.com/jetmech15/gto
Less said,,,,,,,, Less mended.
Old 03-10-2001, 01:09 AM
slowbird's Avatar
Thanks now the only question I have is where can I get 37 degree flaring kit. Is that just a normal flaring kit or is that a special angle. With kind of help I will have the car running in no time!
Old 03-10-2001, 07:12 AM
Craig Berkheimer Craig Berkheimer is offline
I use a regular flaring tool sold at any hardware store. It has like 5 different sizes for different pipe. Lowe's has it for $19.99. These work well on aluminun pipe but tend to wear out when used repetivley on steel such as brake lines. As far as the 37 degree flare, I know nothing about that. I do know that I've had no problems with the tool I use.
Outlaw Pontiac Racers Association
"For Those Who Live The Legend"
www.outlawpontiacs.com
JBP 416ci on Gasoline
#16 Dports 10.75:1 Compression
Weight - 3300 lbs
10.5 - 29.5 TIRE
Best ET: 60ft=1.39
1/8 =6.49@104mph
1/4 =10.29 @ 129mph
Old 03-10-2001, 10:54 AM
TinInjun's Avatar
Slowbird:
You can find a 37 degree flaring tool at any aviation tool supply store. Where are you getting your AN fittings from? They should have one also.
Old 03-12-2001, 01:41 PM
Herb Hagan's Avatar
Herb Hagan Herb Hagan is offline
slowbird,
Try Grainger or McMaster-Carr, they carry 37 degree flaring tools. There is a wide range in prices, more expensive models are designed to do stainless tubing.
Good luck,
Herb
74 Ventura 462/#13 heads/3350#
10.38 @ 128.89 MPH, N/A, Stock suspension, 275/60 Radial, Street legal, Tagged & Insured
