Yes I have. I didn't realise how different they were from the old slapper bars. It felt the same but the timing tickets tell the difference!!!
With a 1.4 60ft time and 125 mph..should be 10's all day.
And what matters is the preload at the lifter. You sink the nut 1/2 turn past zero lash on a 7/16-20 stud, the nut goes down .025. The lifter plunger goes down more than that. How much more depends on the rocker ratio. |
See post 17 |
After reading this here and elsewhere and not finding anyone who gave a measurement I put a dial indicator on the rocker, inline with the pushrod. 1.55 rocker ratio. One turn on the polylock resulted in .070 preload.
Frank M. 75 Firebird 68 Firebird 400 RAIII 66 Chevy II 461 Pontiac in AZ |
That means 3/4 turn will be a scooch over .050 preload with a 1.5 rocker ratio. I believe lower ratio rockers will give more preload b/c the rocker ratio is working backwards.
.050 X 1.55 = .0775. Your real-life measurement is .0075 away from theoretical. First Guess: The seven-and-a-half thousandths is easily explained by imperfect rocker ratio, and potentially imperfect measurement-tool set up. 3/4 turn = .050 x .75 = .0375 at the stud. .0375 x 1.55 = .0581 lifter preload. The rocker ratio is not "backwards". Last edited by Schurkey; 02-02-2023 at 01:38 AM. |
Thanks again. The shift light comes on at 5800 RPM just as I'm going over the line. No more revs to go. As I previously said either converter slip or wrong gears, but, I really don't want to go faster in a convertible.
I have 1.65 ratio rockers so, will the measurement be increased or decreased ? The polyloc is obviously not quite central. |
In that case it is even more preload than the .050 that has been said by 1 turn of the nut.
The Following User Says Thank You to tooski For This Useful Post: | ||
How do I put a picture up please?
when you post a reply, click the "go advanced" button, that will open a manage attachments window, click "choose file" & find the pic you want to post, then click upload. after that finish typing the message & hit reply.
Nope. doesn't want to work.
RT 60ft 330 1/8 1/8mph 1000ft 1000mph 1/4 1/4mph 0,143 1.7105 4.8643. 7.4049. 97.26. 9.5960. 111.64. 11.4427. 122.48 This is a timeslip I had but not the quickest. I cant find the quickest one. |
should work, i post pics using the steps i posted & pics always show up...
times look great, my 467 stroker firebird does 120-123mph at 11.2-11.3 but i have crappy 60ft times due to stiff suspension not set up for drag racing & some fuel starvation issues with a mech pump. Last edited by 78w72; 02-04-2023 at 10:40 AM. |
Thanks. Times look great, lots of potential.
