Performance Parts For Sale/Wanted Just Performance, non-stock, trailers, tools and related accessories here.
Old 03-03-2023, 05:13 PM
chiphead's Avatar
chiphead chiphead is offline
Default BOP TH350s for sale
I have (2) TH350s for sale. Both are short tail BOP bellhousing. I'm going TH400 and don't need these.
Built TH350 $1100 OBO
The first was rebuilt by me in about 2018 and never used. It has most of the upgrades for a high HP Lemans/GTO.
hardened input shaft
36 element intermediate sprag and hardened race
4L60E bolt-in center support
pistons machined for 5 clutches
quality clutches/steels
performance clearances
all new bushings/bearings/seals
Transgo stage 2 shift kit for auto or manual shifting.
cast aluminum deep pan
red stripe modulator
replacement gov with yellow springs
Comes with extra tailhousing, apply pistons cut for 5 frictions and a box of gaskets and small bits.
Built but damaged TH350 $200 OBO
The other tranny is built just like the first, except it has a stock input shaft, stock TH350 intermediate sprag and hardened race. It was run street/strip for a few years. The tranny rolled the sprag and cracked the bellhousing on a nitrous pass, so it's parts only. Most of the internals, VB and pan still good. Could be fixed with an ultrabell.
Buy both for $1000. Act now and I'll throw in the home-made holding fixture that fits an engine stand. Both trannys are in the Aiken SC/Augusta GA area. Local pickup only. PM if interested.
ID:	608266   Click image for larger version
ID:	608267   Click image for larger version
Old 03-27-2023, 03:54 PM
chiphead's Avatar
Bump
I found some of the receipts for the parts used, like the hardened input shaft and fwd drum.
Built th350 $900 obo
Old 04-11-2023, 11:30 PM
chiphead's Avatar
Bump
Built unit $750 OBO. Cost me more than that to build it.
Parts unit $125 OBO. Good center support, planets, clutches, VB, pan, etc.
Old 04-27-2023, 01:17 PM
chiphead's Avatar
Bump
I can provide more pictures. For an offer close to asking price, I'd be willing to pull the front pump and take pics/doublecheck internal clearances.
Make me a fair offer for both, I need the space.
Old 05-06-2023, 10:37 AM
Are you coming to Norwalk this year?
Old 05-06-2023, 08:51 PM
ta-69's Avatar
ta-69 ta-69 is offline
Pm sent
Old 05-22-2023, 08:39 AM
ta-69's Avatar
Is the transmission still for sale?
Old 05-24-2023, 11:10 AM
chiphead's Avatar
Yes, its still available. I didn't see a PM, sorry! Send me a PM or leave a message here and I'll get back to you. I'm not going to Norwalk but maybe we can work something out.
Old 05-24-2023, 12:55 PM
ta-69's Avatar
I'm in Hinesville Georgia. You can call me at 603 477 7984. Thanks Jim
Old 06-07-2023, 07:37 AM
chiphead's Avatar
Built TH350 Sold, thanks PY!
TH350 parts tranny still available. Will part out, PM me with needs.
Old 01-04-2024, 02:32 PM
chiphead's Avatar
Bump Final call before I junk this TH350 parts tranny.
Anybody need hard parts or clutches? Free, just pay shipping from 29803.
Any interest in aftermarket TH350 cast aluminum deep pan, pickup extension and bolts? It's a good pan, drain plug, no leaks. $75 plus shipping
How about the whole valvebody with the Transgo 2 shift kit, includes spacer plates? $25 plus shipping.
I'll post pics when I get a minute. I'll take check, MO, Paypal.
Old 01-05-2024, 12:19 PM
chiphead's Avatar
I tore the parts tranny down last night. All the internal parts are good. I forgot I put all my good leftover parts in this broken case. Direct drum is good, hardened sprag is good, all the red performance clutches, steels and planets are good, etc. The sun gear and shell are the good, thick ones. Note the BOP specific tail housing and speedo gears.
If you had a good case, you could build a working unit with these parts. Will sell the whole lot or part out.
ID:	626007   Click image for larger version
Old 01-31-2024, 07:51 AM
chiphead's Avatar
Bump
Old 04-05-2024, 11:40 PM
chiphead's Avatar
FWD drum and input shaft, clutches, band, other parts sold. Thanks PY!
Still have the
4L60E style bolt-in center support. $80
Double bushed sun gear with heavy wall sun shell $50
direct drum, planets, output shaft, valvebody with TG shift kit, TG plate, 6" tailshaft, various other TH350 bits. Make offer plus shipping to lower 48.
ID:	631620   Click image for larger version
ID:	631621   Click image for larger version
ID:	631622   Click image for larger version
