My gosh, people sensitive about oil filter changes. I did not know that.
Been through a CASE of GM Delco filters from PY ( a very important award from ~2006). Well i got 1 left, and have gotten other filters free with the new oil. Seems i best slow down on filter swaps. |
If I have time I let it drain a few hours. If I don't, I change it whenever I can. As long as it gets done I'm happy.
Hot is what I was tot. 🤫
Jeff |
I don't think anyone is saying bypass filtration doesn't work, I think it's more like people are tired of the endless infomercial everytime a oil thread is posted ,
They work does everyone need or want one NO ! Hearing the same repetative information over and over and over is in fact an annoyance to alot of people iam sure there is TV commercials your tired of as an example The best time to change your oil is when you feel like it hot or cold within time and mileage guidelines not what filtration to use .
A man who falls for everything stands for nothing. Last edited by Formulas; 12-30-2020 at 05:32 PM. |
The Following User Says Thank You to Formulas For This Useful Post: | ||
I just change it. If the oil is warm, fine, if the car has been sitting for weeks and it's ice cold, that's fine too.
I pre fill the filter on cars that allow it, and don't on cars that wont allow it.
"Those poor souls have made the fatal mistake of surrounding us. Now we can fire in any direction" 1970 Trans Am RAIII 4 speed 1971 Trans Am 5.3 LM7 1977 Trans Am W72 Y82 1987 Grand National |
You should run for office
MOre importantly where to you dump it at :
Neighbors lawn in the shape of a swastika Lake Sewer Bottom of the trash bag Leave it at Costco parking lot Drain it in a dirt field ( like they do in Europe) Put it in the same gallon jug, return it for your money back Pour it in your ex wife’s trunk Put it in the garbage outside Starbucks Pour it on a black top road, sit back and have a beer Send it to that guy you hate on the forum Or all the above
🧩 Burds Parts, Finding those Hard to Find PCs, no Fisher Price Toys Here Just Say No To 8” Flakes pause pause F ire B irds 🇮🇱 |
lol
Seriously, I've always been amazed at how people can overcomplicate and overanalyze something so simple.
Especially in this place. |
So how do you keep your socks, folded or singles.
Well……
Some people say I'm a baller so...……….. |
Why do they have to be mutually exclusive? What if you want to fold all of them as singles? Is there even such as thing as a single sock? Because even if they're mismatched, you always wear two. And what about half socks? |
Would you believe...
“Nothing in the world can take the place of persistence. Talent will not; nothing is more common than unsuccessful men with talent. Genius will not; unrewarded genius is almost a proverb. Education will not; the world is full of educated derelicts. Persistence and determination alone are omnipotent. The slogan Press On! has solved and always will solve the problems of the human race.” ― Calvin Coolidge |
Not sure why you'd let the oil drain for hours. Many engines contain quite a bit of oil even after draining. I know at least one honda has 1.1qt of oil still in the motor after pulling the drain plug and changing filter. They list 3 fill specs, initial dry fill, fill without filter, and w/filter. Initial dry fill is 1.1qt more then fill w/filter.
Because personal shops are not GM Quick Lube locations
#38
I believe it's wise to drain the oil when hot or warm while some contaminants are in suspension. That is not a complicated concept.
BONESTOCK GOATS '64 GTO Tripower Hardtop (Wife's Car) '64 GTO Tripower Post Coupe (My Car) '99 Bonneville SE Sedan |
#39
462 Yc Block, zero deck Probe forged pistons 6cc relief, Scatt Hbeam rods floating pins aprox. 10.21 CR Comp Hyd-roller cam,roller lifters,springs ect. 236 244@ .050 108 LSA .511 lift, duration 289,297 @.oo6 Edelbrock Aluminum 87cc round port heads Larger valves ,ported polished and cut Powerjection3,T2 manifold, Try-y’s Flowcooler water pump. 71 formula with TKO600,hydraulic clutch 3.42 posi and 26 inch tire. 17x9 YO Honeycombs with Nitto 555's |
The Following User Says Thank You to lfdsteve For This Useful Post: | ||
#40
And that relates to how much oil is up inside a running engine when you figure how much oil to run. And also how much oil inside your oil filter when running, and the oil pan capacity, etc.
Example the popular Canton Road Race pan, they state 6-quart "system" capacity. By that they mean 5 quarts for the pan itself and 1 quart for the oil filter. That said, almost all popular filters used do not hold 1 quart of oil. And those who run remote mounted oil filters, how much oil are in your lines. .
Closed Thread |
