distributor shaft roll pin shearing off?
Has anyone ever heard of the roll pin holding the gear on the distributor shaft shearing off on a Pontiac engine due to heavy weight oil, a high volume oil pump, or any reason at all?
Yes, not real common though.
Is it an early 1/8" pin? Pull it and just look it over reinstall a new pin and don't sweat it. Likely had some inclusion to cause it to shear. Definitely look for signs of gear being overly loose on shaft. |
I'd be looking for bits of the plastic timing gear or valve stem seal going through the oil pump.
You Stilll have a nylon coated cam gear in that motor!!!!
Yep. Me. Had 3 of them sheer. Mallory Unilite. Small roll pins though. The new Unilites have a larger roll pin. My engine also has the 80# pump. It pegs at 100 until it warms up. Then it will run 30 at idle and 80 at speed. This engine has run since the 80`s though, so no "bearing wash out" here. Still runs hard today.
Thank you for the responses. I Googled the sheared roll pin thing and the only ones that came up were those on Fords and a couple of them were Unilites, so apparently Unilites can be a problem in any brand.
I asked because I am doing some SD clones distributors out of '55/'56 Pontiacs and someone told me I needed to put larger roll pins in, and I had never heard of one shearing off so thought I would ask. |
I would install a new oil pump with the p body mod and a new intermediate shaft. AND investigate what ever you found in the oil pan.
Bull Nose Formula-461, 6x-4, Q-jet, HEI, TH400, 8.5 3.08, superslowjunk |
What is this?
Roll pins, just like most everything else has different levels of quality and strength.
Always a tradeoff between the diameter of the pin/hole and strength of the actual shaft. I have seen a few mods where the stock pin was replaced with a solid pin that was .0005" larger than the hole in the shaft and pressed in place. Much harder to shear a solid pin of good steel. Tom Vaught
