Old 11-29-2005, 05:42 PM
JD's Avatar
JD JD is offline
Default KRE Aluminum High-Port Update?
Hey Kev
I see you and KRE have updated your websites with new information on the the KRE High-Ports.
http://www.tinindianperformance.com/...iac%20head.htm
Do you have any more specifics like spring diameter, valve length and installed height? Any pictures on the intake side? Is the intake valve canted like the Wenzler Series II? Is the pushrod hole the choke point and does KRE put the pushrod hole in the head as part of their final machining process?
Old 11-29-2005, 06:02 PM
WARPed's Avatar
WARPed WARPed is offline
The valves supposedly will be 6.2”, but what pushrod length will be needed when compared to a common 72cc Edelbrock?
1994 Formula
535ci NA CV-1 - single 1050 with c14 - 940hp@7000/825tq@5200
Pontiac Powered 4th Gen Project Progress
Old 11-29-2005, 06:33 PM
Steve C. Steve C. is offline
If interested there are some pictures of a High-Port head posted on the Pontiac Zone website under the topic of KRE High-Port heads. Some are side-by-side comparisions with it and Edelbrock heads.
Old 11-29-2005, 07:07 PM
SLICK1 SLICK1 is offline
Thumbs up
THANKS STEVE C.!!! I'M ON BOARD FINALLY.
(see it in action)
http://video.tinypic.com/player.php?v=2sbpmkm
Old 11-29-2005, 07:22 PM
slowbird's Avatar
slowbird slowbird is offline
Series II heads dont have cant valve. (I believe anyway). If you buy the heads with the standard pushrod location, that area will be the choke point.
Old 11-29-2005, 09:02 PM
slowbird's Avatar
What intake was used on the 900hp engine?
Old 11-29-2005, 09:05 PM
ErikW's Avatar
ErikW ErikW is offline
Does the Victor fit with those heads?
Old 11-29-2005, 09:07 PM
ventura7211's Avatar
ventura7211 ventura7211 is offline
Steve,
Do you have a link to that thread, I must have overlooked it.
thanks,
lance
Old 11-29-2005, 09:18 PM
JD's Avatar
JD JD is offline
According to the Wenzler website the Series II head has a
2 degree "splayed" intake pushrods = no pushrod bulge
Here is a link:
http://my.execpc.com/~lewenz/heads1.htm
Old 11-29-2005, 09:34 PM
slowbird's Avatar
Yes the pushrods are move over alittle (making that angle) but the valves are still staight up (no cant).
Old 11-29-2005, 09:40 PM
JD's Avatar
JD JD is offline
Unhappy
Sorry, my bad. Looks like I need to slow down and read a little better.
Also here the link requested earlier
http://www.pontiaczone.com/forum/showthread.php?t=11725
Old 11-30-2005, 12:16 AM
crossbreed455's Avatar
crossbreed455 crossbreed455 is offline
yes it does. that is one of the first things i asked Jeff.
Thanks Mike M
Old 11-30-2005, 12:44 AM
KEV's Avatar
KEV KEV is offline
Post More info....
Hey guys!
Yes we have updated the web sites!!!! Nice to see you found the info
On the questions......
Yes victor fits with NO mods. Spacer is cast into the head. Just bolt it on. I believe the BOP intake will be made to fit the High Ports as well.
The intake valves are not canted. Standard Pontiac 14 deg valve angle
Series II head is not canted. Not aware of any Pontiac head with a canted valve.... yet
Valves are 6.200 long.
I used 10.400 3/8 length pushrods on my combo (if I remember correctly)
The pushrod holes are a part of the final mach process. As noted on the web page they are either standard location or .700 offset. Standard location is good to approx 370 cfm and the 380 + cfm will be .700 offset You need to tell us what way you want to go on the pushrod holes before they are machined.
Kev
Kevin Swaney
Tin Indian Performance Rear Engine Dragster 7.66 @ 172 mph 494 with KRE High Port Heads
330-699-1358
Old 11-30-2005, 01:28 AM
BVR421's Avatar
BVR421 BVR421 is offline
sure.. any day now
I dont need more pictures. I need my heads. Maybe next week. Maybe. LOL
Old 11-30-2005, 11:51 AM
I believe for a solid roller application the Comp 959 springs or equilvent have been used. The 959's are 1.645 in diameter and it would work out at about 2.000 installed height.
Old 11-30-2005, 12:58 PM
Ken -Ace- Brewer's Avatar
Ken -Ace- Brewer Ken -Ace- Brewer is offline
Send a message via Yahoo to Ken -Ace- Brewer
Shaft Rockers are also available for the KRE's! For only $795!! They are 100% American made! And ALL fasteners and hardware are ARP!! And our price BLOWS away the competition(Jesel & T&D)!
Be Cool,
Ace
Am I glad I got out of the business I was in? HELL YEAH!!!
Old 11-30-2005, 01:25 PM
mikeb mikeb is offline
Sure would be nice if those mid-80 cc heads were on the horizon
Old 11-30-2005, 10:54 PM
shaggy69gradprix's Avatar
shaggy69gradprix shaggy69gradprix is offline
Red face high-ports
well i just recieved my bare castings i ordered & just relized im only going to be able to get 370 out of them my push rod holes were allready drilled. i was hoping to get closs to 400cfm mabey they will let me swap them out.
Old 12-01-2005, 01:09 AM
KEV's Avatar
KEV KEV is offline
Default give a call tomorrow.....
Shaggy give a call tomorrow @ KRE or shoot Jeff or I an email. I'm sure it won't be a problem. We will get it sorted out.....
740-599-5000 KRE
kre@ecr.net
or kevin.swaney@tinindianperformance.com
330-923-8606
Anyone looking for a bare set
Kev
Kevin Swaney
330-699-1358
Old 12-01-2005, 09:14 AM
Thumbs up thank you
let me tell u looking at the castings these are a top qualty casting no junk.i was very impressed.
