Old 03-26-2005, 11:10 AM
Judge Man Judge Man is offline
To the right of the timing chain cover the WT is stamped on the block.right above the WT is another # but its not vertical,there 7 #'s.Are these 7#'s part of the vin that suppost to match the car?Or is the vin# stamped on a shelf on the block?
  #42
Old 03-26-2005, 01:24 PM
Where would the built sheet be located in a 70 Tempest?
  #43
Old 03-26-2005, 04:26 PM
gtoric's Avatar
gtoric gtoric is offline
The V.I.N. should be stamped vertically on the RH front of the block about half way up. You will have to look behind the lower coolant hose to see the number stamp. The number near the top, over the engine code stamp is the engine unit number. This number does not correlate to the V.I.N. in any way. Build sheets can be found in several locations, but not in every car. Some of the more common locations are on top of the gas tank, under the rear seat upper or lower cushion, and under the carpet.
CDN2PLS2, what are the color totals for Granada Gold, Verdoro Green, Palisade Green, Palladium Silver, and Baja Gold
  #44
Old 03-26-2005, 05:03 PM
CDN2PLS2 CDN2PLS2 is offline
Is that ALL!
Granada Gold=114
Baja Gold=82
Palladium Silver=60
Verdoro Green=71
Palisade Green=86
Looks like none were built Orbit Orange,Too Bad!!
Old 03-26-2005, 05:45 PM
Thanks for the info everybody.While were on colors how about a cardnialred 70 GT-37?
  #46
Old 03-26-2005, 05:47 PM
The 70 GT-37 I bought is a Fremont car,how many were made there?
  #47
Old 03-26-2005, 06:29 PM
Jack Peters's Avatar
The numbers and codes are "supposed" to be stamped in a specific location. On occasion, and it seems to be Freemont, the numbers and letters are there but not in the correct locations and sometimes upside down. Who knows what they were smoking back then when this was done. See example of my block. Last diget of sn is almost not legible.
JLP
  #48
Old 03-26-2005, 07:06 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by CDN2PLS2:
I mean it's stamped vertical.
No Aztec Gold in '70 </div></BLOCKQUOTE>
my bad, mine's a 71 forgot this post was dealing with 70 only.
mike
former." --Albert Einstein
- Winston Churchill
  #49
Old 03-26-2005, 07:39 PM
You mentioned that sometimes the vin# is'nt in the same location,were would that be?Are the vin#'s stamp good enough onto the block to read?On the block is there just one area for the vin#?Or is there more than one place to look?
  #50
Old 03-26-2005, 08:07 PM
Fremont built 321GTz,61 with 400
Cardinal Red=189
Old 03-26-2005, 08:54 PM
supcarbob's Avatar
supcarbob supcarbob is offline
Our dealership did have/sold an Orbit Orange GT-37 in 1970. Had a 400 2bbl/auto with hood tach.
Also,does any body own/owned a 400 4bbl/manual trans 1970 GT-37?I would love to see a build sheet/PHS on one of those.
  #52
Old 03-26-2005, 09:53 PM
That's odd because Fred Simmonds papers break down all 1419 GT-37z by colour,but not a OO one.
Old 03-26-2005, 09:55 PM
On Vacation
My friend has one and I have seen the build sheet. He even offered me a copy, but I declined - I felt funny having it.
  #54
Old 03-26-2005, 10:22 PM
Judgeman,
The numbers/codes will be on the machined area below the rh head and beside the timing chain cover. HOW they are stamped varies. How they are shown on http://www.walaceracing.com is how they are SUPPOSED to be stamped. But as you can see on my block they are in the correct area but not in the place they are supposed to be. The last number on my block is so faint that is is almost unreadable.
JLP
  #55
Old 03-26-2005, 10:43 PM
supcarbob's Avatar
copy of invoice for GT-37 in Orbit Orange. No 'extra cost' for color...
  #56
Old 03-27-2005, 05:41 AM
CND2PLS2 thanks for the info I appreciate it.The info on these GT cars that you have does it give any production breakdown for the transmission?And a breakdown for HT and coupe?
  #57
Old 03-27-2005, 05:44 AM
Jack Peters thanks for the information you provided I appreciate it.I'm going to check on that today,I'll get back with everybody and let you guys know if its a # matching car.
  #58
Old 03-27-2005, 09:26 AM
Well I cleaned the flat surface off to the metal on the block just below the lower radiator hose,and I cant see any kind of stamping of any numbers?Unless the numbers are so faint that I cant see them,but I had a flash light at every angle trying to see if there were any numbers there no numbers.I took a wire brush and then I scrape the surface and then spray it off with brake cleaner,I kept doing that untell I was to the bare metal.
  #59
Old 03-27-2005, 09:29 AM
I appreciate all the help I can get.If I cant read the vin on the block,is there another way to tell if the motor matchs the vin on the car?
  #60
Old 03-27-2005, 09:47 AM
No other breakdown on body styles or pwr train.
That's a cool sheet on OO GT.Couldn,t be many that colour.Think it's still around?
