Old 08-05-2021, 09:04 AM
ponchorob ponchorob is offline
Default lookin for 428 block
im lookin for a standard 428 block to bore my own 428 4 bolt was cracked so i need a new one ...would appreciate any help for finding one.. thanks robert
Old 08-05-2021, 09:54 AM
AG's Avatar
AG AG is offline
I have a 1967 4 bolt 428 YH block std bore in NH with the std/std armasteel crankshaft.
1967 Firechicken, 499", Edl heads, 262/266@0.050" duration and 0.627"/0.643 lift SR cam, 3.90 gear, 28" tire, 3550#. 10.01@134.3 mph with a 1.45 60'. Still WAY under the rollbar rule.
Old 08-05-2021, 11:25 AM
steve25 steve25 is offline
Why don't you grind or drill out the ends of the crack and have that cylinder sleeved, as that would be cheaper than buying a block?
Old 08-05-2021, 12:38 PM
sdbob sdbob is offline
I've been running one sleeve in a SD block,+.030. Block has over 200 runs in stock configuration though.
Old 08-08-2021, 05:06 PM
"QUICK-SILVER" "QUICK-SILVER" is online now
Default Just Asking
ponchorob,
Will your pistons work in a standard bore 455? Might give you more options to choose from in your search.
Do you have connections in the US to inspect and arrange shipping?
Clay
Thread Tools
Display Modes
