Old 08-18-2021, 10:29 PM
CraigG.'s Avatar
CraigG. CraigG. is offline
Default Hi compression starter
Hey everybody,
I have a 13 to 1 465 and using E 85 – I have an IMI high torque standard version gear reduction starter.
When in the heat in staging I get really stressed sometimes to start and stop when moving the car - especially if it stalls and getting it restarted. Usually does fine but not always – especially On hot days.
Does anyone have a recommendation and or suggestion about race duty starters – perhaps knows about the differences in the top end IMI Starters?
Thanks again, Craig
Old 08-18-2021, 10:39 PM
ID67goat's Avatar
ID67goat ID67goat is offline
What is you timing while cranking?
Maybe you just need a starter retard or ignition switch to let the motor spin up a little before firing?
Old 08-18-2021, 10:40 PM
Johnny406's Avatar
Johnny406 Johnny406 is offline
Similar situation myself with my E-85 463. I'm planning on going to a RobbMc starter this winter.
https://www.robbmcperformance.com/pr...c_starter.html
Johnny US Army Retired
1978 T/A 463 Pontiac, KRE 74cc 292CFM D-ports, Lunati VooDoo, V-max lifters, TKII, ATM 850 E85 carb, TCI TH-350 race tranny, 3600 converter 3.73 12 bolt 11.63@116.68mph
1981 T/A 4-speed 406 Pontiac, Merrick ported 6X heads, Comp 270S cam, Crosswind intake 750 Street Demon, 3.42 30 spline Eaton posi street car.
1980 Formula 350 Pontiac back burner project
1972 LeMans 350 Pontiac
Old 08-18-2021, 11:57 PM
CraigG.'s Avatar
I have a starter retard 10 degrees and 36 total.
Thanks, Craig
Old 08-19-2021, 12:22 AM
slowbird's Avatar
slowbird slowbird is offline
A separate ign switch from the strarter really helps. Absolutely the best thing is put a 16v battery in. Starters love the extra volts
Old 08-19-2021, 07:42 AM
67Fbird's Avatar
67Fbird 67Fbird is offline
^^^^ all the above ...PLUS instead of another switch to hit for the ignition you could wire in a delay relay for your ignition power.
Old 08-19-2021, 07:57 AM
AG's Avatar
AG AG is offline
I use a relay for the starter solenoid.
Old 08-19-2021, 07:58 AM
Scott65's Avatar
Scott65 Scott65 is offline
You need more start retard. Is it adjustable? If so 20 degrees start retard will help.
Old 08-19-2021, 08:18 AM
Don 79 TA Don 79 TA is offline
IMI makes a few starters, might want to see if they can upgrade yours
do you have really good battery cables? i'll assume yes
i like the upgraded IMI i have now, forgot what its called or the part number, but Butler had it
however i am using dougs 1 7/8" headers so there is "breathing" room around the starter so to speak
but i do have locked timing with no retard, and no issues, but again i'm also just slightly under 11:1
Old 08-19-2021, 09:34 AM
lakefect lakefect is offline
iam 15 to 1 no timing retard. xs starter and 16 volts,spins over like the plugs are out
Old 08-19-2021, 11:38 AM
CraigG.'s Avatar
What do you have to do to convert to 16 V?
Old 08-19-2021, 12:00 PM
CraigG.'s Avatar
I also have a switch for the Starting timing retard for 10 or 20 and the distributor rotor is phased. Some E 85 Racers say that more than 10° retard makes it harder to start.
The motor does kickback when hot so I've used an ignition switch to switch on once the motor is turning over and still will stop Or slow down.
Do people use the a body frame for the ground from the engine to the battery in the trunk or do they run a separate cable for the ground?
Do people have experience with the RobMc performance starters and how the additional starter support for motors that kickback?
Thanks, Craig
Old 08-19-2021, 12:11 PM
Scott65's Avatar
I'm an exception to the "normal race car" as I use efi and coil near plug, but I ran my battery ground from the trunk to the engine block 00 cable like the positive. Mostly for ground loops, but helps with cranking too in my opinion. Also I use 6° advance for cranking timing all the time whether on gasoline or E85. I switch back and forth at will. Try the 20° retard before throwing money at it.
Old 08-20-2021, 09:37 AM
nothing buy a battery and charger,best investment you will ever make
Old 08-20-2021, 10:11 AM
CraigG.'s Avatar
suggestions - where to buy?
Old 08-20-2021, 10:24 AM
Scott65's Avatar
If you run an alternator, do some research on how 16v will work with the current one. Likely to need something different. Even 14v batteries need an upgrade to the alternator to work well.
Old 08-20-2021, 11:25 AM
Pontiac Performance Author
With the H-O trunk mount battery kit we included 37' of 00 gauge fine wire welding cable. Had the customer run the ground wire directly to the starter bolt.
A quick test to see if the problem is timing related, disconnect the ignition and crank.
Old 08-20-2021, 12:07 PM
I used the exact same 00 gage fine wire welding cable in my 64 GTO for years.
A very good welding shop had it and it was not expensive.
Only change I made was to use a Ford Solenoid on the fender with a 00 gage wire from that to the Horn Relay Starter Connection.
I used the spare tire "loop" to hold the remove-able Battery Box in the trunk.
I ran a -4 ground cable from the battery box to a bolt on the Bellhousing to the engine.
Old 08-20-2021, 04:35 PM
CraigG.'s Avatar
Tom 4 AWG?
Thanks, Craig
Old 08-20-2021, 06:04 PM
4 AWG welding copper cable.
