#221
Hi, Jimmo
Good to hear all is well I suggest you try a GOODYEAR Gatorback belt. The ribs have diagonal grove segments cutting the ribs in segments of several sizes. I think this helps prevent cracking and checking on the ribs. One other suggestion, on your installation you bolted the tension idler pulley on the 5/16" water pump bolt. When I installed the tension idler put tension on the belt, I could see a deflection of the bolt. I drilled the idler bolt holes to 3/8" and bolted the tension idler in the upper 3/8 bolt.
Its ok to giggle and snicker, Dont laugh and point Last edited by Ollie; 01-29-2013 at 09:31 PM. |
#222
Jimmo, glad you are well.
PM sent. Russ |
#223
Ollie,
Just thinking out loud here, but do you think if the tensioner was moved to where the idler is, and vice versa, then the system would work with or w/o A/C? I know my '95 F150 has a tensioner that is fairly compact. If something like that were rotated toward the alt-P/S pump, it would tension back toward the W/P pulley. I made a red arrow on you pic from above- what do you think?
John IG: @crawdaddycustoms YouTube: https://www.youtube.com/channel/UCK9...Nc_lk1Q/videos |
#224
Wait... I think that's Jimmo's setup. Maybe I spoke too soon.
#225
Yes, that is Jimmo's set up.
This is my set up. check Arrowhead post 147 He installed the serpentine belt to the alternator and power steering pump. and a separate V belt to the AC compressor. He bolted the idler to the alternator bracket as Jimmo"s original installation. The belt tension would be adjusted by moving the alternator. Reported back in post167, Ran hard at Norwalk. Reported no problems. Maybe send Arrowhead a pm and ask how the setup with out the spring tension idler is working after this length of time. Go on YouTube type in serpentine belt. There are several good instruction videos put out by Dayco.
Its ok to giggle and snicker, Dont laugh and point Last edited by Ollie; 01-30-2013 at 04:20 PM. |
#226
coming into this kinda late in the game but perhaps you can adjust the depth of WP pulley by moving the flange on the shaft by that .070,then no need for spacers. I didnt read thru the whole 12 pages so if someone already mentioned,ignore.
Everything comes and goes Pleasure moves on too early And trouble leaves too slow |
#227
More info
Arrowhead sent me a pm a lil while back with what sounds like exactly the same issue. It happened to him 1st but we both wrote it off as he thought he may have overtightened the belt. Now that I had the same issue we can rule out "tensioner vs no tensioner". Also I can rule out my ac compressor alignment. Thats what made me look toward the alt pulley as suspect. If it happens again I will definately be scratchin my head but I will find the culprit, especially with the help of everyone on this forum.
On another topic. The optimal position for a tensioner is right after the crank pulley to pick up the slack of the stretching belt except of course when the belt goes directly to a reverse driven waterpump where that would be impossible. The crank is the "driving" pulley and all the others are "driven". If you watch the tensioner on any serp system you can see the tensioner swing in and out with the load of the accessories. Without the tensioner the belt slaps around. If its going up a short distance to the waterpump like my 1st system its not a problem but going all the way to the ac compressor I thought would be an issue so thats why I installed it there. Ive seen tensioners in other places, like between the ac and alternator but most of the system I checked out had them after the crank. |
#228
There are no spacers on the waterpump pulley, unless Im forgetting something |
#229
Like Jimmo said, I had the same thing happen back in September, the front-most rib of my belt separated. I figured it was stressed from 6 passes at Norwalk and that I had it just a little too tight. I will be changing out the VW alternator pulley now as well.
I took this pic just tonight...note that the idler is polished on half of it's contact face with the belt, and the belt is shiny in the same travel path area as well. Obviously uneven loading against the pulley face but what is the root cause? There is no belt squealing. I wonder if may be necessary to weld some reinforcement metal to the backside of the alternator bracket at the idler pulley mount, to prevent pulley deflection.
Red\black 65 Grand Prix 467 E-head stroker, Viper T-56 6-speed, 4.10 spool |
#230
From the looks of things, I'd say that your alternator pulley is misaligned. You need to make sure that everything lines up with a straightedge when everything's in tension.
You could also be misaligned, vertically, with the idler. But the alternator, from the picture, appears to be oul of true. If you think about it, objectively, you can visualize what could give you that pattern.
Rich The real democratic American idea is, not that every man shall be on a level with every other man, but that every man shall have liberty to be what God made him, without hindrance. Henry Ward Beecher "The problem with socialism is that you eventually run out of other people's money." Margaret Thatcher |
#231
You can move the WP pulley and eliminate the crank spacer
#232
Take the idler off,put a large crescent wrench on the bracket exactly perpendicular to the angle belt is at when the pulley is in place pull the wrench towards front of motor. this will tweak the bracket slightly and put the pulley in the proper plane. In other words the front of idler pulley needs to go down slightly. Bracket looks heavy enough. To check your angle you can put a very long bolt in the hole the idler would mount in. the longer the bolt the more the angle will be noticeable. Also make sure the idler doesnt have any slop in it Grab by the pulley without a belt on and see if you can wiggle it.
#233
Thank you all for your suggestions, will investigate the situation further this weekend. I hadn't really noticed the odd idler wear until I saw this thread had came alive again recently and figured I'd better check it out.
#234
Arrowhed, When you drilled the hole in the alternator bracket did you use a drill press?
If you drilled with a hand drill the hole may not be perpendicular to the bracket causing the belt to not track properly. Check this YouTube video, showing the correct belt installation. The belt was installed on an engine with out a front clip for clarity. http://www.youtube.com/watch?v=sBGAPMId4Ds Also on you tube use the search words "Serpentine belt alignment. Here's another good video. Ensure the belt ribs are alinged in the groves. http://www.youtube.com/watch?v=sBGAPMId4Ds
Its ok to giggle and snicker, Dont laugh and point Last edited by Ollie; 01-31-2013 at 05:56 PM. |
#235
I did in fact use a drill press, the hole size is right on, and deburred the hole. Not to mention the large spacer Jimmo supplied would surely square the idler to the bracket. I'm leaning towards alternator alignment...will be checking it out much closer soon enough.
#236
if you need a pm your address I have 9, will send one to you. Go back through Jimmo's post there is quite a discussion on alternator pulley alignment. I found some 0.203 spacers on E-bay from this seller.
Its ok to giggle and snicker, Dont laugh and point Last edited by Ollie; 01-31-2013 at 06:15 PM. |
#237
This happened many years ago before the serp install. |
#238
Yes, I agree, don't move the water pump pulley. The water pump pulley and the crank pulley should align using the AC delete spacer. I belive it was determined the alternator pulley required about a 1/4" spacer. All other pulleys and idlers are aligned to the crank and water pump pulley .
Its ok to giggle and snicker, Dont laugh and point |
#239
when checking alignment of anything remember
String is your friend
#240
Yea, your eyes can play tricks on you. Also camera angles play trick too. Arowhed's system might be dead on in person even though the photo does not reflect that. Ive taken so many photos and sifted thru before posting. Ive had quite a few that distorded my system also.
I did use string when setting mine up. Also a straight edge and one of those picture hanging red laser lines. If ya stare at it long enough it still plays tricks on ya. I also used everyone who visited me to look at it and tell me if they thought it was crooked. One thing about using the straight edge is that all the pulleys have a different size front lip so ya cant use the lip as the guide. I measured off of it and back to the first rib of each pulley. |
