Old 08-26-2005, 10:12 PM
Bryan Jensen's Avatar
Bryan Jensen Bryan Jensen is offline
On Vacation
Send a message via AIM to Bryan Jensen
Default Recommended paint for H.O./Ram Air Manifolds??
I purchased the 67 High Output style manifolds from our host for my 67 goat, and I'd like to put on some sort of coating on them to keep them protected.
I purchased some Engine Enamel that when you spray it on it looks like brand new cast iron. However the paint is rated up to 500 degrees. Now I know the exhaust portion of the car gets pretty hot, but how hot I'm not sure. Is the stuff I bought going to cut it or am I going to have to buy another exhaust paint with a higher temperature rating?? Don't want to put in the effort of putting it on only to find out once I actually get the car going again that the paint is chipping.
Old 08-26-2005, 10:19 PM
Larry Navarro's Avatar
POR-15 "black velvet" manifold coating
Old 08-26-2005, 11:38 PM
On Vacation
Talking
Thanks a BUNCH, went ahead and ordered it right after you put up the recommendation. Any special or good way to put it on?
Old 08-27-2005, 10:39 AM
follow the instructions on the label and you'll be fine.
Old 08-28-2005, 10:11 PM
Jim Doran's Avatar
Jim Doran Jim Doran is offline
I used the eastwood exhaust manifold paint w/a foam applicator as the suggest. Looks great and has last quite well over several long distance drives. On my pontiac, I also covered the center two exhaust ports on the head since the pontiac blue always burns off as well.
-Jim Doran-
1965 389 Tripower; 4 speed; convertible
2019 Tesla Model 3 Performance
2016 Chevy SS; Sold
2001 Toyota Tacoma 4x4
2008 Infiniti G35x
Old 08-30-2005, 12:21 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
Someone on these boards said they had good luck pre-painting the exhaust ports with Eastwood's Stainless, then painting the whole head with color- Pontiac blue, of course! I'm trying that on my heads, but it will be a while before I run it and can post feedback.
Old 09-04-2005, 05:43 PM
Mopey2 Mopey2 is offline
Default Exhaust Manifold Paint
I've used Nucast high temp by VHT Paints. Looks great and is rated to 1500 degrees.
Old 09-27-2005, 10:20 AM
RR67GTO's Avatar
RR67GTO RR67GTO is offline
I was thinking about this and really there is nothing wrong with just leaving them as cast. A car that's used will look used and although trying to maintain a clean look if fine. So is allowing them to "properly age" the way any driven car will. Besides, if they are rusty you can spot a leak faster.
Build it fast, build it right, hold On TIGHT !!!
Old 09-29-2005, 11:37 PM
norton70 norton70 is offline
wouldnt u want the cast iron por vs POR-15 "black velvet" manifold coating. i would think black velvet is black..isnt it?...as for doing the heads first, i would think u would use por-20 which is silver so if the blue paint does peel, at least u have a fbright lake color underneath
