Option 3 swap out those heads for snag heads, have low compression get yourself a turn cam and a 88 MM turbo and run 900 HP at low boost and drive your car anywhere on pump gas !
Then you can put a 3.08 gear in it and enjoy the car and still go faster than you’ve ever gone before I have a RAIV and a RAV dual quad set up they are both puppies compared to my turbo car ! And my turbo car is far more forgiving to drive anywhere . It’s been together forever and not even a plug change! My turbo car is also built in a budget That’s far less than the other two
Happiness is just a turbocharger away! 960 HP @ 11 psi, 9.70 at 146. Iron heads, iron stock 2 bolt block , stock crank, 9 years haven't even changed a spark plug! selling turbos and turbo related parts since 2005! |
If it were me I would run round ports, all about the power in my book.
I have to use a smaller brake booster for my High Ports so there is that. Turbo would be cool, never done one though. Have some 4X 455 heads that would work. Doing a high effort pump gas High Port 461 right now. All the bells and whistles. Yes I got the screen shots of the E heads off Edelbrocks website. |
Sean 1967 GTO Koerner built 468 with Edelbrock RP’s 315cfm by Butler, Luanti Voodoo HR 20510713, 4l80e, Holley Terminator EFI |
If you are really making 520 from your current combo, you may not be overly impressed with another 40 at the motor. Not really helping you spend your money…..good luck on the build!
71 GTO, 463, KRE 295 cfm heads ported by SD Performance, RPM intake, Qjet, Dougs Headers, Comp cams HR 246/252 ...11 to 1 , 3.55 cogs, 3985lbs.....day three- 11.04 at 120mph ....1.53 60', 6.98 1/8 mile |
One thing that you have going for this upgrade is your current head/cam package is a well thought out package. It is worth money, when you do the swap keep track of all the lifters, pushrods, rockers etc. Somebody will buy them it will offset the cost. Makes a huge difference that is a known performer..and the heads are professionally done.
It is very easy to achieve 600 hp..and after checking out your build , I assume an overdrive is in the future. So how does a mild street mannered 600 hp engine sound with good vacuum that pulls 20mpg on the highway sound?
I installed a built 4l80e in April of 2020. Probably the best mod to the car. Makes a pleasure to drive. Now I just gotta figure out how to get 20mpg outta this thing……
I was easily 16 mpg plus on long drives. That was with 308 gears. Mild duration and lots of lift, and higher compression go a long way.
This was with a basically stock Holley 950 HP
Option #1 Will make more then you will ever need on the street and be dangerous anyway w street tires.
Your trans If its an Auto will NOT last either, a TH400 cannot handle that torque in stock OEM guts!! You will Find weal links there definitely. Or your clutch if its Not a center force type setup. And a Stock GM rear won't last either. Welcome to the familiar 1-2-3 row thru your running gear to make it live scenario.... Don't over focus on the engine bay you have a choir of thing in the soup! |
