#81
Thanks Steve. It’s actually an Allen-head plug (size 8). I don’t have an Oxy torch. I have a MAPP torch, if you think that might work. I can also just run to the hardware store and get a couple to see what fits. It’s definitely bigger than 1/2 in. Here’s what it looks like: Sent from my iPhone using Tapatalk
Three times the sound peaks, falls back, peaks again. A throttling back to cruising speed, a dwindling grumble of thunder and...gone. The frogs take up where they left off. |
#82
#83
I think the plug is a 9/16. The OD measured around .572 on my caliper, and it looks like there is a threaded insert in there. Advance Auto has these in stock, so I'll grab one at lunch time. Assuming it fits, do I need to put anything on the threads for sealant purposes?
#84
You will find the correct electrical specifications in the 1966 Tempest Shop Manual.
The primary resistance in coil, measured over + and - on coil should read 1.8-2.0 Ohms. The secondary resistance, measured over either + OR - and center terminal should read 7200-9500 Ohms (may read up to 16000 Ohms without fault). With ignition ON and points closed you should read 5-7 volts over + on coil and chassis ground. Measured with engine running measured this way you should read around 11 volts (around 14 volts over battery terminals). HTH |
#85
Just trying to be logical here. Did the engine builder provide you a complete running engine with a guarantee? Did he install the motor and give you back a running car? In either case, if the work was performed recently, take it back to him and him and let him resolve the problems.
If an excessive amount of time has passed since it was rebuilt, or it was a motor/no accessories build, you are stuck trouble shooting it yourself.
Triple Black 1971 GTO Last edited by NeighborsComplaint; 09-30-2021 at 12:43 PM. |
#86
My BAD here, Yes I have several coils measure 6-15 K OHMS not 6-15 OHMS.
Big difference there, sorry. If all else fails and cannot figure it our by 3PM today, I'll offer you $2,500 and take it off your hands, Hate to see a Pontiac owner have to go thru this stuff. |
#87
#88
The primary resistance was 2.6 Secondary resistance was 16800 Sent from my iPhone using Tapatalk
#89
Yeah, your "best if used by date" is long gone. plus you added your own accessories so you're on you're on your own even with a brand new build.
Triple Black 1971 GTO |
#90
2.6 on coil only makes weaker sparks on plugs, than the correct 1.8-2.0 Ohms. Any markings on coil? BTW, resitor wire on most, if not all, GM vehicles with points ignition is 1.3 Ohms for a total of 3.1-3.3 Ohms running running. |
#91
So this will make absolutely no sense. The new Accel points got delivered. I put them in (along with new condenser) but car would not start. I put the old points in, but left new condenser, and all of a sudden car idles just fine. I took it around the block for a test drive and it was running just like it did before the problem started. Until I tried to really get on it, then it felt like ti would cut-out at higher RPM at full throttle, It definitely idles better and cruises fine. Is it possible that a failed condenser was my issue? Why wouldn't the Accel points get the car running?
#92
One would have to assume that the new points where either not opening or not closing.
A resistance test would tell you if there shorted even when you hold the points open with some paper or card board.
#93
And one more thing, I did disconnect the fuel inlet (after car was sitting for about 1 hr) and no fuel spilled out. Might I still have a fuel-pump issue. Is the fuel bowl supposed to remain full of fuel, even after you shut car off? Is the in-line filter (before the carb) supposed to only allow fuel to flow one way?
#94
The filter is not one-way. The fuel pump is designed not to allow back-flow when off.
If the pump is failing and allows backflow, the siphon could empty the fuel bowl when you turn the engine off.
Did you test your fuel pressure? We've had a couple pumps get eaten up by that piss-gas they are selling nowadays. They would pump fuel, but only generate about 1.5-2psi. Enough to idle and low-speed cruise but not enough to drive aggressively. Sounds like the condenser was definitely one of the problems. |
#95
Most folks won't check the lead resistance. My meter leads are pretty consistent at 0.2 ohms. Crappy or damaged leads can be higher-resistance, or even variable. Quote:
Defective? Installed wrong? "Protective coating" on the contacts not allowing current flow? Quote:
Yes, and I like that you infer that it's "ONE OF the problemS". There's clearly more than one. Last edited by Schurkey; 10-01-2021 at 03:17 PM. |
#96
Rig up a pressure gauge to view it see what it reads.
Observe if it is steady 6-7PSI delivery. Needs to be at idle and in normal driving mode too. If not start inspecting things= Pump etc. |
#97
So i was able to drive it over to my friends shop just to have him check the timing and see if he had any ideas. He installed one of those breakerless SE modules he had (he's a Buick guy) and set the timing. He was originally setting it to 38, but I thought that was a bit much for this car so he moved it back to 35 degrees total, but he said the timing was erratic on occasion it was erratic and it would backfire a little at idle. He asked if I might have a tight valve, but I didn't think that was the case because it ran fine or the first 300 miles or so. He suggested just swapping over the cap and wires from my Trans Am, just to make sure there wasn't a bad wire or something. I drove it home and you could still feel the stutter so clearly the timing alone wasn't the problem. The car died at the bottom of my driveway. When I went to restart it, all it would do is backfire (and flames would pop out of the carb). I called him and he thought that I might have water in my gas? Does that sound right? Car is sort of stuck on my street right now.
#98
Have you swapped the cap and wires as he suggested? I would also do the coil.
Hoping to finish a project while I'm still able to push the clutch in.... 1963 Tempest Convertible (195-1bbl, 3-speed transaxle. 428 RAIV, 5-speed, IRS planned) Pictures |
#99
Water in the fuel will not make it back fire and neither will a coil!
A bad coil might make it not start, or miss if started, but not back fire. If it’s something to do misfire wise stemming from the distributor then swapping in a known good cap and rotor should tell you something, as should swapping over the plug wires if need be. Also unstable timing makes me think you could have a timing chain issue going on, especially if the timing is drifting around!
#100
Thanks. After it sat for about 30 min, it did start. I was able to nurse it up the driveway and back in the garage. I'm going to try swapping things (one by one). First I'm going to replace the black wire that goes from the negative side of coil to the points (now breaker less module). That is the only wire that doesn't feel supple. It's not worn through or frayed, but the insulation feels cracked. I have another Pontiac distributor so I can just swap tag wire pretty quickly. The one on my other distributor feels much more supple.
