Old 05-18-2021, 07:15 AM
455-4+1's Avatar
455-4+1 455-4+1 is offline
Default Factory bore tolerance stamps
Pulled down a few engines recently that looked to be pretty original.
On the decks were stamped letters near each bore, possibly designating tolerance post hone?.
S, T etc.
Does anyone have any information on these tolerance stamps, if they are indeed that.
Stamping looks pretty uniform, so may have been machine probed, then stamped, and assembly guy picked a corresponding piston to suit to try and close up tolerance?
Working on going faster (and now staying dry at the same time !!)
Old 05-18-2021, 08:35 AM
PunchT37's Avatar
PunchT37 PunchT37 is offline
Go to 5:29 on this vid.
https://www.youtube.com/watch?v=9LuXf6gJ-jg
Old 05-18-2021, 08:50 AM
AG's Avatar
AG AG is offline
Those stamps indicated which piston size would go in that hole, pistons were "select fit".
1967 Firechicken, 499", Edl heads, 262/266@0.050" duration and 0.627"/0.643 lift SR cam, 3.90 gear, 28" tire, 3550#. 10.01@134.3 mph with a 1.45 60'. Still WAY under the rollbar rule.
Old 05-18-2021, 09:24 AM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
What AG said. Patt Lobb is a big 409 guy(also owns a big Toyota dealership above Dallas in Allen). He has a conference table size blueprints of the 409 blocks and it has table for them what letter is for what bore size piston. And hence the term "fitted block" for factory blocks.
Skip Fix
Old 05-18-2021, 10:01 AM
In some years they changed the letters. (SD 455 is one I believe)
I have a Craftsman Service News on one of the changes. It also showed the specs for each letter.
Old 05-21-2021, 05:37 PM
455-4+1's Avatar
Pretty cool, would be interested in the specs if available?
Thread Tools
Display Modes
