4L80E CONTROLLER
OK, what brand should I get, there appears to be quite a few different types available now.
Your car must be very fast ! Because you were haulin ass when I passed you in my GTO. |
I used a TCI controller. Worked great once I worked a few bugs on my end. Their tech help is very good too
62' Lemans, Nostalgia Super Stock, 541 CI, IA2 block, billet 4.5" crank, Ross, Wide port Edelbrocks, Gustram intake, 2 4150 style BLP carbs, 2.10 Turbo 400, 9" w/4:30 gears, 8.76 @153, 3100lbs |
If you like getting in depth with the laptop and changing things like how long you want to hold shifts to the next gear when you let off the throttle (like for turning corners) so it's not gear hunting and other things like 4th gear delay at certain throttle percentages so you aren't in an out of 4th gear, adjusting how much engine braking you want, and all the other small details to really make the trans act exactly like you want it to,,,, Then you'll like the US Shift Quick 4 tuner.
It does all the simple stuff with a hand held tuner if you don't want to get too involved, but allows very precise changes of everything if you want to plug a laptop in. |
The Following User Says Thank You to Formulajones For This Useful Post: | ||
Two other recent threads.
US Shift Quick 4 is the best
1964 GTO 501, Edelbrock Heads NA, 3460 lbs. 9.76 @ 137mph 1971 Trans Am Lucy Blue, 11.56 @ 115 1966 LeMans. 462, SD prepped Kaufman D ports. 11.90 @ 112 1976 Trans Am twin turbo 462, SD Edelbrock heads 8.50@159 2009 G8 GT |
The Following User Says Thank You to ErikW For This Useful Post: | ||
I run a USShift quick 4 with my 4l80 setup and it is sweet! Super easy to setup and tune. Actually I will be selling mine soon because I am ordering a Holley Terminator Stealth EFI setup that comes with transmission control.
Sean 1967 GTO Koerner built 468 with Edelbrock RP’s 315cfm by Butler, Luanti Voodoo HR 20510713, 4l80e, Holley Terminator EFI |
The Following User Says Thank You to sjdiesel For This Useful Post: | ||
"No replacement for displacement!" GTOAA--https://www.gtoaa.org/ |
Thread Tools | |
Display Modes | |
