Thanks Pastry, I just edited my post above (#19) while you were posting a reply, just incase you missed it
1978 Trans Am Pump Gas 461 Stroker |
We will do the full sweep with the 9.150" and report back in just a few minutes
Ok, here is full sweep with the 9.150" pushrod and 1 full turn of the engine. Lifter at zero lash.
Post 23 looks like about as good as you'll get.
Edit.. maybe 9.2 is better,, looks more narrow IMO. Last edited by pastry_chef; 06-27-2021 at 10:14 PM. |
The Following User Says Thank You to pastry_chef For This Useful Post: | ||
Here is the witness marks, one on the base circle, one at 2/3 lift, both with the lifter at Zero Lash, at 9.150".
I was thinking by the time a person preloads the lifter .050" or so, the 9.200" may end up being the best, although the witness mark on the 9.150 is pretty centered, but that is WITHOUT any lifter preload too. I am by far not an expert though, that's why I need help LOL
Are your factory rockers new or used and can you post up a pic of the contact face on them.
Would be interested to see the diff in radius of the contact area on the stamped rocker, Vs the radius of a common roller tip rocker
Working on going faster (and now staying dry at the same time !!) |
We are checking with the factory rockers, but they are in excellent condition. We will be using New Comp Cams replacement 1251-16 though, which are exact specification as the stock rocker that we are measuring with. We are still awaiting delivery of the new rockers, so we are measuring with the stock rocker, but since they are identical specs, there should be no difference between the two as far as pushrod length. I don't have any pictures of the stamped rocker contact face at this time, but I can get a picture this evening.
I would wait till new rockers are in hand the new face at the tip might make pushrod checking easier due to a new surface
The Following User Says Thank You to Formulas For This Useful Post: | ||
I'd also wait for the new rockers. |
ALL rocker ratios vary slightly from manufacturer to manufacturer and style to style. Since you are going to all this trouble to get an optimum-length pushrod, make certain that it is optimum with your NEW rockers. |
The Following User Says Thank You to Joe's Garage For This Useful Post: | ||
Thanks guys!, as far as what I have measured so far(with the current stock rockers), what length do you guys favor the most? I was leaning towards the 9.200" by the time a person figures in .050" or so of lifter Preload. We will definitely check it with the new rockers when we get them.
I vote for the 9.200”.
While you have some time it would be interesting to cycle thru all of those stock rockers on that one valve just to see how much the ratio veries.
The Following User Says Thank You to steve25 For This Useful Post: | ||
Ok guys, we got the new rockers today, and remeasured using the adjustable pushrod at 9.200". To me, the witness marks look even better with the new rockers, and I think the 9.200" is the winner. One mark is on the basecircle, the other is at 2/3 lift, both with the lifter at ZERO lash. By the time a person figures in .050" of lash, I think the 9.200" will be as close as we can get. We also measured with it at 9.150" appreas to be a little too short.
Looks good.
Thanks! I'm gonna go ahead and place my order at Butlers for the 9.200" .116" wall. I appreciate all of your help very much.
Thread Tools | |
Display Modes | |
