Old 02-10-2018, 10:56 AM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
Default Some ideas for you boost folks :)
http://www.hotrod.com/articles/centr...er-1963-style/
Came across this thought you all might get a kick out of it. And yes a W block motor.
Skip Fix
Old 02-10-2018, 12:13 PM
Tom Vaught's Avatar
Boost Engineer
A LOT of very Nice Fabrication on that Dragster Skip. Say 600 cfm Carbs, a Paxton industrial Ball Drive compressor system inside the snout cover, the large Compressor Wheel and Housing. It would have made some power but probably not live long on the street as the bearings were not up to it for long duration runs.
The Paxton Supercharger design was used on World War II Submarines to exchange the bad air for good air inside the hull.
Usually 1 unit installed in each of several areas in the sub to replace the bad air with good air from above the sea.
Tom V.
Old 02-11-2018, 07:40 PM
Skip Fix's Avatar
Looks like the factory dual quad intake and they just moved the two AFBs over.
Skip Fix
Old 02-11-2018, 08:31 PM
Tom Vaught's Avatar
Boost Engineer
X2
Tom V.
