From radials to slicks!Cant wait to race tonight!
Well...anybody wanna take a stab at what the new ET's will be vs. old radial street tires? I went with 26 x 11.50 X 15's . old tires were 27.2 inches tall with ZERO traction. New ones are Mickey Thompson et streets. Current best is a 12.54 at 113 with a 1.98 60 ft....give or take. I would like to see 11.99... anybody think it is possible?
434 CI TKO600RR 1969 Carousel Red RAII Heads...Pump gas 400+hp/450+tq at the wheels...life is good! |
Yes, be prepared to hook! What rear gear?
Derek B. Current best: 11.97@110 1.65-60' !!! '74 ventura, (Fired july 14/06) '74 462 4-bolt (9.5-1), SCAT, Ross, T-II w/850DP (shaker455), TH350, Conti 10'' 3800, Supercomps, Magnaflow, 3'' Pypes, 3.73's, 28x13.5-15 ET streets. 1970 Beismeyer 17' flatbottom vdrive, 11.8:1 455P, ported heads, dual Qjet tunnel ram. |
If you can get the 60' down to a 1.79 it will pull off a 12.19 @111.0-112.7 MPH. Notice the slight MPH loss, this is from the "Lugging" force the car will experience with traction! Anything quicker than this will require a much better 60' time, which will depend on the suspension and the willingness of the driver to launch it hard. Good LUCK! JD
P.S. If you could maintain the same MPH with everything remaining the same you would need roughly a 1.67 60' time to crack the 11.99
Good luck to the new owner of the Ventura II! Sold the car after 13+ years. Look for it on the Hot Rod Power Tour in the future as it's currently being re-configured as a Pro-Touring ride! |
thanks
Tires or the diff/driveshaft?
I suppose
Rear end is a new moser 12 bolt with 35 spline axles and diff is detroit tru trac ....should be ok...the drive shaft is factory with some good u-joints..i thought the drive shafts were good to 600hp...
run it..no pain no gain..if your gonna pussyfoot it all the time why go to the strip..
I saw the title of this thread and had to laugh, because i'm going the other way. The latest "hot" thing at our local tracks are "factory rubber shootouts". Rear tires have to be "real" street tires (no drag radials or bogus DOT approvals on an obvious race tire); you can run the biggest meats you can fit under the car. Also, you can run any power adder you want. I think the racing in this class is going to be exciting.
As far as your deal you are going to be shocked at the traction difference. |
I twisted my factory driveshaft in
half running low 12.0's. I'll bet 12 teens. |
1978 ,t/a 3660# 455 2010 / 1/8 7.86 1/4 12.40 @ 109,19 http://www.youtube.com/watch?v=6PaHbLnszS0 http://www.youtube.com/watch?v=XMxhM...eature=related 12.01@109 http://www.youtube.com/watch?v=MC-dganA2jQ 100 shot 11.78. A,ll new head cam combo 96 ported bye Mike Chell!! Comp cam yes the 284 XE. Firsthand outing of the street 7.69 1/8 12.15 109.47 hot and humid.not hooking. 1.73 60. |
I predict at least 2 tenths drop, you will like it not having to ease into the throttle |
If your car dead hooks you may find you'll need some carb tuning to eliminate any bogs. Tire spin covers up alot of tuning issues. Also try leaving from a dead idle as well as loading up the converter. You may find better 60" times using a lower stage RPM than you think. Above all HAVE FUN!
Standard transmissions don't have convertors
No substitute for traction! Once you get the launch optimized I am pretty sure you will see those 11's coming up. On the Bird we are still tinkering with the suspension to be able to launch the car up on the converter; as yet the best 60' is 1.63 but the best e.t. was on a 1.66 with a little wheel spin. If you can knock 3 tenths off your 60' you are well on your way. I have a lot of respect for you guys who can make it all happen rowing the gears. Autos take a lot of the guess work out of it. Good luck.
69 Bird w/1970 400 block(409 cubes), #64 heads, hyd. roller, Q-jet by Jeff E., original interior, ps, pdb, th350, and 3.73 gears. Pump gas, street driven muscle. 3800 lbs. race weight. Best, 11.39 @118, my son's car. 79 T/A w/463, Scat crank, Eagle rods, Icon pistons, Lunati solid roller, 262/270, KRE 325 heads, Northwind intake, QF950 carb, full interior, ps, pdb, th350, and 3.73 gears. Pump gas, 3650 lbs. race weight. 10.68 @ 126 so far... no tuning yet. |
Rev up the sucker & dump that clutch, chicken ??? It's only parts you'll break. Really, be patient, find your sweet spot. Just make sure something is slipping. Clutch, tires or somethink else WILL break. I,ve launched mine up to 6k & been real lucky to not break something major yet. Just have funnnnnnnnnnnnn.
See Ya Dave
New Motor: 6-13-12 P-Dude 67 GTO 406, 670 heads, RPM, 750 Holley P-Dude Cam, M-22 4-speed, Centerforce clutch, 12-Bolt 4.56 275/60R15 M/T Drag Radials Old Motor: New PB 4-21-11 : 12.460 @ 109.97 1.844 60' ' |
I am not sure if you'll see .55 from the swap. But you will find out quick what your weak spot is. The smaller tire will rpm higher so your engine may like it and give you a bit more, or may not.
Good Luck.
68 Firebird Are you running with the wind or breaking it? |
Your best bet is to launch at a higher RPM say 4000 but pump your tires up so they spin, then slowly lower them till they just turn a couple of rotations.. If you car dead hooks something will give, maybe not right away but something really needs to slip a little.
Good luck and let us know how you do.......I am hoping for 11's for yeah, but it is a different deal with a stick!!
1965 GTO hard top, Black with a red interior built to drive and Race best so far 1.45 60’ 8.77@164mph . 6 Speed manual transmission. MS3pro Fuel injection Multiport , 517cubes 10 to 1, 3.50 gears, CNC E-heads wideport 350CFM by Dave B. 4025lbs with driver!!94mm turbo. Winner of the Hot Rod Dragweek stick shoot out 2017! |
So did it hook? Did it break the tires loose or the driveshaft?
The silence is making me worry like something went wrong or broke. Even if the results were less than expected we can help. Hopefully he is ok. JD
