Old 02-01-2021, 12:09 PM
WARCHIEF400 WARCHIEF400 is offline
Default 1970 GTO PARTS
1970 Ram Air 4 bolt main shortblock std. bore needs to go 30 over $4000.00
1970 Quadrajet Carb pulled off running car #7040263 $400.00
1970 AM RADIO WORKS $200.00
1968 HURST DUAL GATE SHIFTER RESTORED$525.00
NOS 1970 Wheel well moldings $850.00
1970 pair of used rear wheel molding $200.00
1970 GTO grill $150.00 single
1970 GTO Front Headlight housing assemblies $300.00
1970 power brake booster $50.00
1970 lower main duct and vents $125.00
1970 Intermediate steering shafts $50.00
1970 Rear Windshields $80.00
1970 Coils $25.00
1970 Oil Filter housings $85.00 each
1970 front lower window reveal molding $60.00
1970 rear front upper fender chrome moldings $30.00 pr.
1970 Throttle cable $45.00
1970 Turbo 400 Transmission oil pans $50.00
1970 NOS FRONT WINDSHIELD UPPER STAINLESS MOLDING $175.00
1970 NOS PASSENGER SIDE FRONT WINDSHIELD STAINLESS MOLDING $90.00
1970 door vents pr. $20.00
1970 positive battery to starter heat shield tube,
1970 window regulators set of 4 $150.00
1970 brake pedal assembly $100.00
1970 emergency brake pedal and bracket $75.00
1970 rear license plate bracket and holder
1970 water thermostat housings $20.00
1970 door hinges $50.00
1968-72 points distributors $80.00
1970 blower motors $25.00
1970 a/c inner boxes $150.00,
1970 headliner bows $50.00 set
1970 Harmonic balancer $50.00
11 Bolt Timing Cover $110.00
11 Bolt Timing Cover withy divider plate and pump $150.00
1970 Full length windage trays $85.00
1970 Show Quality Front Window Stainless Moldings, Professionally Polished $300.00
NOS A/C Delco PVC $9.00,
NOS PULLEY 481040 still in GM BOX $100.00
NOS A/C Delco oil Filters PF 24 $11.00 each
NOS Three prong Thermo Switch for rally gauges $250.00,
1971 GTO Rear Taillight lenses $150.00 Each
1970 Rear Taillight housings $75.00 Each
1969-72 Goldenrod/Tan wheel crack free $125.00
1969-72 auto shifters $135.00
Fuel escentrics $35.00
1970 harmonic balancer $50.00,
flexplates $35.00
1970 inside glove box liner $45.00
1970 Standard Gauge & Speedometer cluster $65.00
1970 GTO/LEMANS Rear window Defroster Switch with wiring harness $150.00
assorted stainless moldings,
1970 driver side lower black dash metal trim $50.00
1970 radio rear support bracket $25.00
1970 Tag light & bracket $15.00
Distributors 1148 Feb13,70, 1253 Jun 26,68, 2007 Nov 28,69, 2189 Apr 24,72, 2513 Nov 15,73 all distributors $80.00
1970 door glass $100.00
used pulleys 481040XT water pump pulley, 481038YB crank pulley, 480507 crank pulley, 8inch 2 grove water pump pulley,
480509
1970 pillar post covers $45.00
new points and condensers __________________
Timmy Mallory Email me at temallory@msn.com
Timmy Mallory
Old 03-24-2021, 04:37 PM
1970 carb 7040263 has been sold.
Timmy Mallory
Old 03-24-2021, 07:00 PM
vertigto's Avatar
vertigto vertigto is offline
Price on the 1970 positive battery to starter heat shield tube??
Also...condition/pics of the TH400 pans??
Old 03-25-2021, 09:49 PM
tigertone tigertone is offline
Hi,
Do you have a rear tailight harness for a 70 gto?
Anthony
