I just secured a new garage and the ceiling is only 8' so a lift is not going to really leave me more than 33" so I may be forced to do this for underneath work instead.
Adam __________________ 1964 LeGTO 469, M21, 3.42 __________________ Sold: 1968 Pontiac LeMans Convertible See it go HERE |
I think they are good for what they can do, but as far as lifting the car for body work, and body panel alignment, no different than regular jack stands. For body panel alignment, it really should be on the wheels. One more thing.....is it going to be high enough for you to get under the car to do anything?
1968 Firebird 400 RAII M21, 3.31 12 bolt, Mayfair Maize. 1977 Trans Am W72 400, TH350, 3.23 T Top Everyone you will ever meet knows something you don't. Bill Nye. |
I would be using it for mechanical work, mostly light work. And I'd probably put either jack stands and/or those wood blocks under the car as backups.
If I was to leave it in the air for any amount of time, I'd want to use this QuickJack to raise the car and then set it down on the tires on those wood crates to avoid frame flex. Since I have just shy of 8' ceilings, a 4 post lift will only give me a maximum of 33" clearance anyway. The QuickJack has extensions that net me about 30" so I'm about the same work height with less cost and more mobility.
The apparatus under the car will make under-car work difficult. Jack stands are bad enough when trying to remove a transmission or install an exhaust system while rolling around on a creeper. Last edited by Schurkey; 06-21-2017 at 02:07 PM. |
For extended time on stands I use the 4 points in the frame diagram but also use 2 stands under the front sway bar bushings. I've even used 2 more at the rear of the frame at times
I made wood blocks from 3 2x4's and 1/2 inch plywood top that go under the stands if I'm using them on asphalt. |
I support mine at the same place Steve does....the sway bar bushings if I want it off the suspension. If I want it on the suspension, I lift at the lower control arm spring pocket as someone mentioned before. Gets the wheels off the ground with much less jacking. In the rear, I lift where the swaybar crosses the differential.
After it's in the air, if I want it on the wheels I use a variety of very large hardwood blocks I've collected over the years. Functionally, about the same as the 2x4 cribs pictured in this thread. I always place stands where needed for security. The quickjack looks handy but as mentioned..overpriced for me. All it would do for me is save me the time it takes to move my jack from one end of the car to another. That would be nice but not enough to pay over a thousand dollars. In the end, all I would do with it is raise the car, place my blocks and stands and then have to move it out of the way...just like my floor jack. As mentioned, for a '68, raising behind the front wheels is scary to look at.
Greg Reid Palmetto, Georgia |
Body mounts and hardware are fine. I'm exaggerating a bit...it's not truly 'scary'... I just don't like seeing the bumper gap open when the weight of the engine is suspended out there. As someone mentioned, it probably occurs on all cars but the endura cars make it obvious.
Jeff |
Check out these safe jack stands.
https://safejacks.com/collections/co...d-by-safe-jack https://youtu.be/UoP9bt1C9Dc I ordered QuickJack 7000 (I have a big jeep too), but I just noticed these and was curious about what others thought. Anyone use them?
http://www.racecarlifts.com/DLMlift.html at the track, in aluminum. They run them over often too. You'll never see me under a car supported by one of them. |
Greg Reid Palmetto, Georgia Last edited by Greg Reid; 09-19-2017 at 08:04 AM. |
Personally, I will stick with the wood platform stands I have and the fabricated stands that use the ACME all-thread screw rod for fine adjustments with a variety of vehicle heights. At some point if I had a lift I would build larger welded together stands basically like this design, (see below). The "Bolt thru the Hole" deal always seems to be in the wrong spot for me.
Tom V.
Now, that is a good idea. It aggravates me when I have to let the car down just a tad or jack it up just a tad to get my stands into a locking position at the height I want it.
