Old 08-27-2009, 09:34 AM
GTO JONES's Avatar
GTO JONES GTO JONES is offline
Default ENGINE COMBO
Has anyone used the 4.75 crank in a 400 block? I'm thinking on doing a 30 over 400 with a 4.75 crank on pump gas (514 cu) !
Old 08-27-2009, 09:38 AM
60man's Avatar
60man 60man is offline
Seems to me Jim Zeek is running a simular combo...thinks it a 506..
He does post on here...
ECM member.
2008 Outlaw Pontiac Drag Series Champion
MANDRA
Do it now fool! Life is short.
69 Grand Prix/3163lbs / IAII 535 w/ Tiger heads by Gaydosh....9.35@ 144 so far.. through mufflers. 1.26 60'.
Going back to track with pump gas engine....
My 60 Ventura retired to street/strip duty..
Old 08-27-2009, 12:18 PM
I can`t see any problem other than The must of 4 bolt steel main caps with studs( which means aling hone time) filling the block to the freeze plugs and keeping the revs to 6k or less should keep the factory block intack.
Old 08-27-2009, 12:20 PM
Wait! I take that back, I do not think that the rods with that stroke will clear the block even with doing as much grinding as much as you can before you hit water!
Old 08-27-2009, 03:31 PM
performerrpm's Avatar
i thought there was a guy on ebay selling 400s with 4.75 strokes, it coulda been 4.5 too tho. its been awhile since i looked there. one things certain, you should beable to pull stumps at idle with it
Old 08-27-2009, 03:57 PM
71 T/A 71 T/A is offline
Butler offers a kit to put a 4.5 crank in a 400, but no 4.75. That should tell you something.
