Fan guard on 67 GTO
Is the fan guard (not shroud) used on all non ac 1967 gto, or do they just get the upper bracket? I thought I knew this, but now, I'm not sure
My 67 non A/C had the fan guard, pretty sure they all did
https://www.facebook.com/KauffmanRac...6873234225938/ KRE 461,310 CFM 85cc, KB pistons, Eagle rods, Ohio crank KRE custom HR236,Dougs ceramic,Edelbrock Pro Flo 4. Quick Performance 9". 552HP 594 TQ |
Andre,
When you say “fan guard”, I’m assuming you mean the metal finger guard up on top that goes around the radiator cap. Every 67 “non-ac” car had these, just like the 65-66 models. Chris.
1) 65 GTO Survivor. 43,440 Original Miles. “Factory” Mayfair Maize Paint with Black Pinstripe, Black Cordova Top, Black Interior, OEM Numbers Matching Powertrain. Purchased from the Lady that bought it new. Baltimore Built (11A). 2) 66 GTO Survivor. “Factory” Cameo Ivory Paint with Red Pinstripe, Red Interior. OEM Numbers Matching Powertrain. Tri-Power (OEM Vacuum Linkage), Automatic "YR" code (1759 Produced). Fremont Built (01B), with the Rare 614 Option. |
Mine does have this guard. I assume the upper bracket is not used in conjunction with this.
You need the bracket on the top to hold the rad, the fan guard goes on top, surrounds the rad cap....
That is correct. And if your core support is missing the nuts that clip in (for the fan guard), Ames sells them. |
Found those nuts at Ace Hardware also.
Thread Tools | |
Display Modes | |
