Worth a shot before I tear it down what should vacuum be at idle ?
after thinking about it the damper lines up with 0tdc #1 comp so I would think it's ok.
Just what I was going to mention Charles. I was wondering how you verified #1 was at TDC. Actually checked for compression or looked at the timing mark?
Greg Reid Palmetto, Georgia |
After researching my cam I found out that it will only pull max 10 inches of vacuum at idle so I know the chin is correct I get 22 inches at midrange 2800rpms my main issue is that I have to put so much timing into it to make it run decent as I mentioned my light has a degree wheel on it so by setting the timing to where it runs decent the light reads 35 degrees adv disconnected if I run it there is no backfire no stumble no detonation I just think this is way to much timing but it's been a long time since I have done any performance applications. Cam specs 231/240 470/470 113.5degrees 112 degrees 10inches vacuum at idle.I degreed it when installed and it was right there Going to talk to a local eng builder see what he prescribes.. |
I your fisrts post you mention you have a mild Isky cam.
Now you describe a cam with RAIV specs? A RAIV-style cam needs at least 15° initial in a 400 or smaller engine and a properly adjusted idle circuit in carb to run decent. The E-clone AFB is NOT up to that task. |
X2 on a cam that will only pull 10"hg needing a bunch if timing. Probably not the best choice for this application.
Jeff |
And the "initial" is Before Top Dead Center. Not at Top Dead Center.
If you cant drive from gas pump to gas pump across the map, its not a street car. http://s207.photobucket.com/albums/b...hop/?start=100 |
Wow what a difference thanks to all..
Well I gotta admit when I'm wrong I'm wrong when I wrote down the info from a friend on #1 position he told me on an HEI it was just before the cap screw so I had wires installed and dropped dist in the wrong position I did not clarify which way was in front towards the eng or towards the firewall turns out it is in front of the screw towards the firewall had the wife help me reset the dist and moved the wires 1 back started first crank idled superbly and best of all timing is at 15 degrees carb balanced out fine 12 inches vacuum at idle took it on a maiden voyage wow what more can I say sweet.
Thanks to all who chimed in remember KISS.. |
The Following User Says Thank You to 1966geeto For This Useful Post: | ||
Congrats!...Just for future reference, the orientation of the distributor cap is always going to be dictated by where the rotor is pointing when the desired piston is at TDC with both valves closed....never by any screw, mark or anything else. You could actually put it on in any position you like, as long as the rotor is pointing to the spark plug wire that will be next to fire.
Anyone...
check the vacuum advance?
"The great obstacle to discovery is not ignorance...but the illusion of knowledge." Daniel J. Boorstein "Gas is STILL your cheapest thrill!" Your opinion of me is none of my business. |
Swap out the carb, I was having the same issue last spring, I installed a edelbrock carb to break in my newly rebuilt 400, I "thought" by using a new carb, it would be one less thing to worry about a first start up, could not get it to run , checked everything, started thinking I was going crazy. I finally installed my original quad( I had not rebuilt yet), turn key, fired up perfect, broke the motor in, I have since put 6,000 miles on it.
So if u have, can borrow, etc ... try a different carb, Also I'm running 744 cam, my initial is 16 degrees, total 34, no vac advance. Having 40 initial timing u r going to have ur rods knocking!!!
1967 Gto h.o., fathom blue, vinyl roof. 400 bored .30 over, 200r4( orginal th400 on stand) fully restored. |
