Old 08-14-2021, 03:50 PM
wbnapier wbnapier is offline
Default Oil Filter Housing Coolant Leak - Help Needed
See photos below.
There was a 4" diameter pool of coolant on the garage floor under my oil filter. Upon inspection, I saw that it was dripping from the bottom of the oil filter housing, where it meets the block. I am unaware of any water passage there.
All nearby freeze plugs are dry. There was some very minimal moisture at the base of the passenger-side coolant nipple on the cylinder head, but no indication coolant is wicking down to the oil filter housing. That nipple was installed with Permatex Aviation.
Is there a water gallery under the oil filter housing? Any ideas?
Thank you.
Name:	1 Coolant Leak.jpg
ID:	571347   Click image for larger version
Name:	2 Coolant Leak.jpg
1965 Pontiac GTO
455/469 w/ #48 Heads, '65 Tri-Power
9.25:1 CR
Stump Puller Cam
Muncie M22W 1st-2.56 2nd-1.75 3rd-1.37 4th-1.00
3.55 Rear Differential
Front: 225/60R15 Height: 25.6"
Rear: 275/60R15 Height: 28"
Old 08-14-2021, 03:55 PM
tom s tom s is offline
has to be coming down from above that housing,maybe the back of the intake?Heater hose barb up that way.tom
Old 08-14-2021, 03:58 PM
That's my working theory. I will go for a drive and then take a look.
Any tips for removing that thing?
What sealant should I use on replacement?
1965 Pontiac GTO
9.25:1 CR
Stump Puller Cam
Old 08-14-2021, 04:40 PM
steve25 steve25 is offline
There’s a thread on here that just got concluded posted by soupman, titled Help! “ Heater hose nipple removal” and your answer lie’s in there.
Old 08-14-2021, 04:53 PM
"QUICK-SILVER" "QUICK-SILVER" is online now
Cross your fingers that its not a core plug in the back of the head.
Think I'd be looking for a pressure tester so you can hunt the leak with the engine cold.
Clay
Old 08-14-2021, 05:15 PM
Usually if mine leaked at the heater fitting or hose connection, it ended up mostly in the valley cover or distributor recess.
I'd go with Clay on the freeze plug in back of head or hopefully not a head gasket leak.
Also look on side of block for a casting thingie(TM) that looks like a wire sticking out of it. Seen them leak before.
Stuff some paper towels behind head area and below head gasket area if possible and around the nipple area.
Run the engine and see which one(s) get wet?
Or the pressure tester as Clay said.
Old 08-14-2021, 05:28 PM
Tom Vaught's Avatar
Boost Engineer
I had a failure of that core plug on my 64 GTO engine, back in college.
It was not the Heater Core Nipple as 64 engines do not have the heater nipple in the back of the head, so a easier diagnosis of the problem.
I had to pull the intake and the head, fix the problem, and I then reinstalled the same head gasket and it sealed fine with a bit of permatex spray on the gasket for many years after that repair. No racing, just street driving.
The correct sized core plug may be a bit hard to find.
Tom V.
