Old 03-08-2014, 11:23 AM
19652plus2 19652plus2 is offline
Default Hayden Fan Clutch Recommendation
I picked up a 7 blade '65 Big Car 19" fan that has a 1 3/4" pitch. Hayden only recommends a Heavy duty(2747) or a severe duty(2797) clutch for a fan with a 2 1/2" pitch. Which fan clutch should I get? Should I go with the Heavy duty anyway or buy a "standard duty" clutch? Thanks for your advice.
Old 03-08-2014, 11:26 AM
70pontiaction 70pontiaction is offline
Thumbs up I'd go with the 2797 clutch if you want it to cool better
Got these (2797s) on several of my Pontiacs with whatever pitch fans they came with - very happy with the clutch performance on every one.
Old 03-08-2014, 11:32 AM
HWYSTR455's Avatar
I too say the 2797, BUT, keep in mind, it kicks in at a lower RPM (which provides better cooling), and can make more noise pulling away from a stop light. On that same note, your pulleys and belts need to be in order to ensure they don't slip, there will be more resistance from the clutch. That gets amplified at higher RPMs, like in the 4500-6000 range.
Old 03-08-2014, 11:49 AM
77 TRASHCAN's Avatar
X2
I've tried the severe duty clutches, They start pulling air too much, for what I needed. I went back to a standard duty thermal clutch, it does the job. A thermal clutch has the bimetal coil in front of it. Some fan clutches are viscous only (have no thermostatic switching, lacking the bimetal coil in front), I wouldn't use one of those...
Shut it off
Shut it off
Old 03-08-2014, 11:50 PM
Did anyone even consider blade pitch when selecting a clutch? Thanks.
Old 03-09-2014, 08:28 AM
68 Firebird's Avatar
68 Firebird 68 Firebird is offline
Default fan pitch
Honestly when I changed over from a 5 blade direct drive to the 7 blade style
I never even measured. The one I purchased was from a 76 Transam with
Auto and AC. Figured being and AC car it would be an improvement.
That and a Hayden HD(2747) clutch and no issues.
Pulls ALOT of air.
How do you measure? From where to where, I will chk and post finding.
Gerry
1968 Firebird 400, 068 cam, TH400 & 13" Continental Converter, Auburn posi with 3:08 factory gears, Cliff's Q-jet resting on a 68 factory iron intake, DUI HEI and Ram Air pans and RARE Long Branch Manifolds
Old 03-09-2014, 10:43 AM
I think "pitch" is measured in the following way. As the fan is lying on a flat surface, you measure up from the surface to the highest point of the blade.
Old 03-09-2014, 12:10 PM
67GTONUT's Avatar
67GTONUT 67GTONUT is offline
I have been using the Heavy Duty for years with great success
Troy
Rockaway NJ
67 GTO
400HO / TKX 3.27 1ST GEAR-.72OD / 3.36 POSI
HOTCHKIS/UMI/BILSTEIN
Old 03-09-2014, 12:15 PM
72LuxuryLeMansLa.'s Avatar
72LuxuryLeMansLa. 72LuxuryLeMansLa. is offline
This isn't a way to measure but....... My 1972 Pontiac Service Manual has a chart for all '72 models. It shows which fan they should have with the number of blades and the pitch listed. So if you have a manual look it up. On my car it is as easy as counting the blades then looking at the chart to get the pitch then buying the clutch for that pitch............
Karl
