Old 05-21-2013, 10:17 PM
estep455's Avatar
estep455 estep455 is offline
Default e head oil drain backs
e head oil drain backs? whos using what and with what success are you having? thanks danny
Old 05-21-2013, 10:29 PM
chiefbigb chiefbigb is offline
I have been putting them on all the e-headed engines I have messed with.Simple to do with minimal cost.My old 66 chassis used to have irratic oil pressure going through the traps without them.I put the engine in a different car with the drain lines on.Oil pressure was now consistant going through the traps.Just my experiance.
Be carefull of the feet you step on today.They may be attached to the a$$ you kiss tomorrow.
Old 05-21-2013, 10:30 PM
mike leech's Avatar
mike leech mike leech is offline
run em on mine. it seems to do ok.
EHTTFMF!
Being dead, it is not hard on you. You don't even know you're dead. It is hard on everyone else that is not dead.
BEING STUPID WORKS THE SAME WAY! The rest of us suffer.
Old 05-22-2013, 12:16 AM
blueghoast's Avatar
Any pics on what they look like.
Just something else I know I should do.
GT.
Old 05-22-2013, 03:12 AM
S/st 54's Avatar
S/st 54 S/st 54 is offline
GT.
X2 while we have the heads off of dads spare motor I'm thinking of doing the same thing.
"You have to evaluate the past,Focus on the future,and that tells you what you have to do in the present"--Lou Holtz
“It’s the process it takes to get to goals that sets us apart, the execution on every single play, one play,one life”
Notre Dame Head Coach Marcus Freeman
69 GTO NHRA Super Street Car
2860lbs 10.890@157.08 MPH in Iowa in June’23 ,157.56 MPH in Gainesville in March ‘23
Old 05-22-2013, 10:18 PM
7D9TA's Avatar
7D9TA 7D9TA is offline
-8 lines from the head to the pan. Works great. No oil puddled in the head when I pull the valve covers.
Name:	oil return line.JPG
ID:	323960   Click image for larger version
Name:	oil return fitting.jpg
79 TA
476, Single 88MM turbo
Street car. Pump gas, Radial tires, Full exhaust, 4000 LB race weight
Best 1/4
1.39 60 ft
9.03@149.55
Old 05-23-2013, 01:52 AM
blueghoast's Avatar
Thanks for the pictures.
It looks easy enough to do.
GT.
Old 05-28-2013, 01:10 AM
Pontirag Pontirag is offline
I think edelbrock had drain back problems on the initial batch of heads. The problem was solved on those heads by carfull grinding and sculpting on the existing drain back holes. Later batches of heads had improved contouring where the oil drained back and pretty much elliminated the problem.
Old 01-29-2024, 08:16 AM
Tim Corcoran's Avatar
I bought my 330 CFM eheads from Dave at SD Performance. Although they have the earlier combustion chamber design Dave did modified the drain back holes to improve drain back. I think the need for putting on the external hoses for improved drain back may be somewhat dependent on the RPM that your engine is running at. Because of my cam specs my converter stall is 4,400 and I shift at 5,600 and shifting any higher does not improve ET or MPH. So at my RPM I don't believe I have any oil starvation issues. If I was shifting at 7,000 or higher then I would definitely install the drain back lines of get an accumulator to prevent oil starvation.
Tim Corcoran
