Pontiac - Street No question too basic here! |
View Poll Results: What type of oil do you use? | |||
Synthetic | 37 | 34.91% | |
Conventional | 55 | 51.89% | |
Blend | 14 | 13.21% | |
Voters: 106. You may not vote on this poll |
X 2. EVERY lubricant we used in turbine engines was synthetic.
“It takes considerable knowledge just to realize the extent of your own ignorance.” Dr. Thomas Sowell |
I'd love to hear a few (possible) wive's tales.
-conventional is less likely to leak (rear main, etc.) than synthetic. -older engines/more miles, do better with conventional. -conventional is better for break in. |
GTO? 15w-40 Delo.
Syn in everything else.
frittering and wasting the hours in an off hand way.... 1969 GTO, 455ci, 230/236 Pontiac Dude's "Butcher Special" Comp hyd roller cam with Crower HIPPO solid roller lifters, Q-jet, Edelbrock P4B-QJ, Doug's headers, ported 6X-8 (97cc) heads, TKO600, 3.73 geared Eaton Tru-Trac 8.5", hydroboost, rear disc brakes......and my greatest mechanical feat....a new heater core. |
Conventional oil promotes lifter spin on flat cams?
'78 Macho T/A DKM#95, 460cid, SRP pistons, KRE 310 D ports, 3" pypes, Hooker 1 3/4" headers, hydraulic roller, 10" Continental, 3.42 gears 11.5 @117.5mph 3900lbs ([_|_] ##\|/##[_|_]) |
I should add that I used to always break in a motor on Valvoline VR-1, run it a thousand miles or so, then switch to synthetic. I believed the rings would seat better. But now AmsOil has come out with a SAE30 break-in oil. So that's what I use now.
http://www.youtube.com/watch?v=t9eWgLd0q-U |
71 Formula 433, Splayed cap 400 block, 4" stroke Scat forged crank, 6.8 Eagle rods, custom Autotec pistons. SD 295 KRE D ports, Old faithful hybrid roller, Torker II, Holley Sniper Stealth, Tribal Tubes, TKO 600, 3.73 Eaton posi. |
Pennzoil Platinum synthetic 10-30W in all my cars, Shell Rotella 15-40W in my diesel truck, but more importantly the Frantz bypass filter to keep it clean and extend the life of any oil you use. There is no spin on full flow filter that will remove the sub 30 micron particulate that spin on filters let continue to circulate through the engine to cause engine wear and the formation of acids and sludge which further degrade the oil and cause even more wear. No matter which oil you use the filter is the most important part of longevity for the oil as well as the engine.
The other oil thread on PY that oils were tested by an independent lab, http://forums.maxperformanceinc.com/...ht=oil+testing Pennzoil synthetic Ultra came out on top of all the oils tested. When I started using the Platinum from Pennzoil it was the top of the line, since then they have come out with the Ultra which is even better in testing. Next time I change oil I believe I'll upgrade to the Ultra. When I started using the Platinum oil it was the top of the line, since then Pennzoil has debuted the Ultra it is a step above the Platinum. The Brad Penn, Royal Purple, Mobil one, and Valvoline oils were not very high on the list and they are highly regarded by the members here on PY. By my own engine failures I would be inclined to believe the test results and as I have determined Pennzoil makes an outstanding product and always has. I switched to it in 1977 after oil related failures in my oval track race engines, solved the oil related problems as soon as I switched. |
Only Pennsylvania grade crude oil for me. Our engines where not designed around synthetic. I'll use pennzoil as my first choice and valvoline as my second. I'm no chemist, but from what I understand the molecules of conventional are just random and synthetic are in chains. When a molecule breaks down in conventional it is suspended along with other contaminants, when a molecule breaks down in synthetic it comes apart like a zipper. I do use rislone zinc additive though with every oil change. I run an 80lb. pump and straight 30wt oil to keep oil pressure in the normal range.
1978 Black & Gold T/A [complete 70 Ram Air III (carb to pan) PQ and 12 bolt], fully loaded, deluxe, WS6, T-Top car - 1972 Formula 455HO Ram Air numbers matching Julep Green - 1971 T/A 455, 320 CFM Eheads, RP cam, Doug's headers, Fuel injection, TKX 5 Spd. 12 Bolt 3.73, 4 wheel disc. All A/C cars |
"Oil molecules do not break down, just the additives." Again, read this......http://www.bobistheoilguy.com/motor-oil-103/ Karl |
Has there ever been a thread or claim of a failure due to bad oil or poor oil product?
Seems it's all preference but in the end, it all does the same thing. No? |
Well, no. I don't believe many folks run or recommend 10,000 mile oil change intervals using dino oil. Synthetics can safely do that.
Karl |
Looks like I' ll be staying with Amsoil after reading that, Brad.
For my 62 wagon build I'll be using AmsOil SAE30 break-in oil, then switch to AmsOil 10w-30. And I'm seriously thinking about adding this...
http://www.amsoil.com/shop/by-produc...l-bypass-unit/
#38
Brad Penn
Brad Penn 10W40 just to throw my 2 cents in. Once I switched to it I had no
lifter noise at startup even after 2 weeks of no use. Used to tap for a few seconds if car was not started for a few days, which is most of the time. Gerry C
1968 Firebird 400, 068 cam, TH400 & 13" Continental Converter, Auburn posi with 3:08 factory gears, Cliff's Q-jet resting on a 68 factory iron intake, DUI HEI and Ram Air pans and RARE Long Branch Manifolds |
#39
The best example I can give is my own experience with conventional vs. synthetic. My 2003 Chevy Silverado had conventional motor oil (5W-30 Pennzoil) for the first two years I owned it. The oil/ oil filter were changed every 5,000 miles. At the 4,000 mile mark, the oil pressure would start to decrease. Not a lot, only about 5psi, but it was throughout the entire RPM range. Since I started using Amsoil, the oil pressure is rock steady throughout the RPM range (30psi at idle, 50psi at cruise). My oil useage has declined and the engine actually runs cooler. I have no problem running the oil for 10,000 miles (oil filter changed at 5,000 miles).
#40
I ran 20-50 VR1 for the first two seasons in this engine and the oil temps were consistently over 230. I switched to 10-40 Royal Purple after reading the testing that was done at bobstheoilguy website. My engine builds oil pressure much faster at cold startup, and the oil temps are about 30 degrees cooler. No noticeable leaks except for the tiny one at the back of the engine which was there with the running of the conventional oil too. With the exception of my Mercruiser I/O I run syn in everything now. If I could find an Amzoil dealer close to me that doesn't want to breed me for the cost of a quart of oil, I would run the Amzoil stuff.
Skinned knuckles and empty wallet! Could I be any happier? 66 GTO Convertible. LS3-525 HP. Legend LGT700 5-speed, Wilwood 4-wheel disc brakes, Ridetech coil over front susp, PMT rear susp, Hotchkis bars, Billet Specialties 18" Dagger's (18X9 rear, 18X8 front). 2002 Ram Air WS.6 convertible Trans Am. Wife's car. |
