Tripower Idle Adjusting Tool
As those of you with Tripowers know, adjusting the idle mixture screws, especially the driver's side on '64 and earlier setups, is nearly impossible.
I have a flexible driver for the hex bits that are common today that works really well! The female hex end is 1/4", so it fits over the idle mixture screw heads. There is no ID of manufacturer on the tool, but I'm guessing Harbor Freight or a similar tool outlet has something like it that would work. The overall length is 16". If any of you have figured out a better way, we're all ears!!!!
BONESTOCK GOATS '64 GTO Tripower Hardtop (Wife's Car) '64 GTO Tripower Post Coupe (My Car) '99 Bonneville SE Sedan |
Thanks Dick!
'04 GTO Yellow Jacket, A4, Kooks, CAI, etc. '02 Firebird, V6, auto '68 GTO Convertible, HO, 4spd, driver '66 LeMans Hardtop, 400, FI, A/C, 4L80E. '64 GTO Hardtop, "389", Tri-power, 5 speed, A/C, Yorktown Blue. http://www.gtoaco.com |
I have a Snap-On/Bluepoint carburetor adjusting tool that has tips for all types of carbs, as well as a ball tipped allen for the the GM distributor points. Had it for 35 years, and still use it. It makes adjusting carbs a snap. It's about 14" long with a 45 degree bend and has an adjustment knob at the top end. Cost about $30 back then, probably over $100 now, if it's still available.......
Jeff |
been looking for something like that for while. cool.
i just use piece of rubber hose. it has to be just the right size. too loose and it slips, too tight and it wont go on... |
Rubber hose is a great idea!! Next time I'm stuck without my adj. tool, that'll be what I use.
I have an adjusting tool like that, Dick, that I bought from a local parts store many years ago. Works very well.
I also had a similar device on my 64 GTO Tri-power set-up that used two of the cables/adjuster sockets (except instead of having a plastic handle the device had 2 1/2" diameter serrated knobs on the end of the cables. The knobs had slots in the middle that a bracket fit into. That bracket mounted to a center carb float bowl screw. So the sockets stayed on the adjusting screws, the knobs turned the cables/sockets/screws and you adjusted everything by turning the knobs on the bracket that cleared the air cleaner base. I could draw you a reasonable drawing (not to scale though) in excel sometime if you wanted further info on the parts. Tom Vaught
I also use them on idle speed screw.. Just stop any of the tool trucks...they should have them onboard. I used to stock 5/6 of them..
ECM member. 2008 Outlaw Pontiac Drag Series Champion MANDRA Do it now fool! Life is short. 69 Grand Prix/3163lbs / IAII 535 w/ Tiger heads by Gaydosh....9.35@ 144 so far.. through mufflers. 1.26 60'. Going back to track with pump gas engine.... My 60 Ventura retired to street/strip duty.. |
Lisle makes one too, I found mine covered in dust on an old parts store shelf a few years back. They are useful for all sorts of things - I even managed to maneuver a power bench seat into the highest positions so I could remove it and service it with that tool and a square bit.
http://www.ebay.com/itm/MAC-Tool-Car...6656ad&vxp=mtr |
Here's a picture of the wonderful access that 64 tri-powers with power brakes have. I found I have a lot better access if I pull the brake hose, but no adjusts while running then. I'd like to shoot the guy that put that drop down area in the carb casting.
For Tripower with power brakes, you need to swivel the fitting up or down to access the idle adj. screw--no matter what tool you're using. I usually lift the rubber hose upward and guide the tool end under the hose.
I have the Snapon/Bluepoint tool also & I have not found a carb it won't adjust. I've had mine to for over 30 years , I know that Snap On still has it as A friend saw me using mine awhile back & he went to the Snap On guy who had to order one for him . Sorry I don't know what he had to pay for his now but mine was $ 25.00 30.00 dollors then. You know it going to be more now.
http://buy1.snapon.com/catalog/item....re&dir=catalog
Keith Collier 61-63 Pontiac Tempest Tech advisor POCI.org |
On the '61 SD Tri-Power of my GMC, I "remoted" the adjustors to knobs/brackets on the front carb. I used some sort of stranded steel cable- probably old speedometer cable. I remember drilling the heads of the idle screws for the cable, but can't remember whether I soldered or brazed the cables into them. Glad I did it- works nicely.
Anybody else on this planet campaign a M/T hemi Pontiac for eleven seasons? ... or has built a record breaking DOHC hemi four cylinder Pontiac? ... or has driven a couple laps of Nuerburgring with Tri-Power Pontiac power?(back in 1967) |
Very Similar to my deal, Jack, except the adjusting knobs were not as thick as your knobs. Brackets mounted about the same. Still have a bunch of that old speedometer
cable, (I came across the other day). Tom Vaught
just snagged one snap on tool off epay..$65 new in wrapper with 6 bits..
I'm bidding on the one OMT linked to. So if one of you guys is bidding against me, stop
It doesn't come with any bits, slotted drive is all I need.
'04 GTO Yellow Jacket, A4, Kooks, CAI, etc. '02 Firebird, V6, auto '68 GTO Convertible, HO, 4spd, driver '66 LeMans Hardtop, 400, FI, A/C, 4L80E. '64 GTO Hardtop, "389", Tri-power, 5 speed, A/C, Yorktown Blue. http://www.gtoaco.com Last edited by ron cozzo; 06-30-2013 at 02:11 PM. |
Thanks everyone for sharing, now I know there is an easier way. I've just been using a long (12") medium screwdriver on my '63 Tri-power and struggling...
Snap-On swings by work every Fri. Something I actually NEED this time (versus want). |
