Old 10-02-2018, 07:37 AM
coonhunter70 coonhunter70 is offline
Default Is this possible
I'd like the simplicity of dumping my exhaust at the rear axle right behind the mufflers but I want to remain fairly quiet definitely no drone, What muffler would you use or is this wishful thinking?
Old 10-02-2018, 10:38 AM
ZeGermanHam's Avatar
Have you done this with any other cars? I've been in lots of muscle cars that are set up like this, and I hate it. It causes a lot of cabin noise (regardless of the muffler you choose) because there are open mufflers directly underneath the floor pan. And then there is the fact that you will smell like exhaust fumes after driving your car for 10 minutes. I'd consider this setup for a drag car, but that's it. I've spent enough time in cars where the exhaust dumps at the muffler to know that it sucks.
1998 BMW 328is (track rat)
Old 10-02-2018, 10:50 AM
george kujanski's Avatar
Nope.....don't do it. Wrong on many levels...exhaust and noise getting into the cabin. Did that when I was young and backed out of it within days.
George
Old 10-02-2018, 12:01 PM
Chris65LeMans's Avatar
In high school, those were called “turn downs”. As has been said - they are loud. I spent many a day cruising in one - then had my ears ringing for some time afterwards.
If you want to “remain fairly quiet,” you don’t want to do that.
Old 10-02-2018, 06:37 PM
Years ago I had a 69 firebird setup like this and yes it was loud, louder than I would want today. I was just wondering if anyone knew of a muffler that might control the noise in this situation. I'm not even sure if a stock type muffler wouldn't be too loud?
Old 10-02-2018, 07:14 PM
Carbon monoxide entering the interior of the car is pretty much a given with exhaust exiting under the floor pans, really not a good way to go.
Old 10-02-2018, 07:44 PM
This.
This. Stinking of exhaust and killing a bunch of brain cells gets old really quickly.
Old 10-04-2018, 11:19 PM
Sprocket's Avatar
Sprocket Sprocket is offline
I ran an axle dump setup in my '70 GTO for years. The pipes were angle to exit roughly behind the rear tire and not just straight over the axle and down. I used Terminator mufflers at the time with headers and 2.5" exhaust. Drone was not an issue, but "remaining fairly quiet" is impossible. For instance, just idling along through a parking garage will set off every car alarm you encounter. Other than that, I loved the sound and fumes in the cabin were a non-issue because of the finish angle of the pipes.
'70 GP Model J
462 Butler ported 87cc Edelbrock D-ports
RPM intake with Holley Sniper 2
CompCams 236/242 hydraulic roller
Tribal Tubes tri-y headers
TH400 13" Continental "Jim Hand Special"
3.50 9" CurrieTrac, 245/45-18 Front, 275/40-18 Rear
Old 10-05-2018, 08:12 AM
Bob with the 66's Avatar
Bob with the 66 Bob with the 66 is offline
I went this route and in my opinion don't even consider this for a street/drag car, the drone, shake, and noise turns the car completely into a drag car. Without a helmet on you don't even want to drive the thing.
"Artificial intelligence is no match for natural stupidity".
1966 GTO Post Coupe, 467ci. N/A Pump gas, best 1/4 11.6 118mph
1966 GTO Post Coupe, "The Bright Idea" 535ci. N/A Pump gas, best 1/4 9.58 141mph
Old 10-06-2018, 06:46 PM
Donovan Donovan is offline
I did this on my 68 FB with a new Pypes system at the time. They sent me 2nd gen tails so I just had the shop put on dumps right after the dynomax turbos.
It sounded amazing especially through the mid-range. But the drone off-idle and the booming at idle got old. I think I drove it on and off for year before getting the right tails in. Tail pipes make an exponential difference in noise level.
Even with quiet 2.5 turbo mufflers it was LOUD. The fact you are asking if it's possible tells me it's the wrong idea for you
I thought it was exhilarating at full throttle!
Old 10-06-2018, 08:23 PM
Lee's Avatar
Lee Lee is offline
Maybe if you use some stock Honda Civic mufflers. the sound will be reasonable, You'll lose a LOT of power, but it probably won't be too loud.
'73 T/A (clone). Low budget stock headed 8.3:1 455, 222/242 116lsa .443/.435 cam. FAST Sportsman EFI, 315rwhp/385rwtq on 87 octane. 13.12 @103.2, 1.91 60'.
My webpage http://lnlpd.com/home
Old 10-07-2018, 01:03 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
Somewhat related to this topic-
My '37 Buick coupe (Pontiac Tri-Power engine) had glass-packs and short 90 degree tailpipes that came out under the rear of the running boards. No drone, no fumes in car.
Old 10-07-2018, 03:09 AM
The exhaust contains moisture and corrosive acids which will attack the underside of your floor and anything else under there..
Old 10-07-2018, 11:42 AM
Alright thanks for the responses
