View Poll Results: Bare or painted
Bare 18 48.65%
Painted 19 51.35%
Voters: 37. You may not vote on this poll
Old 09-29-2018, 10:21 PM
64speed's Avatar
64speed 64speed is offline
Default Painted or bare
Going with Edelbrock heads on my 64 Tempest and was wondering what people would think looked the best cause I am on the fence. Painted the proper egg shell blue color or bare? Rest of block is blue except water pump is aluminum and finned aluminum valve covers have been bead blasted for a matte finish.
Old 09-29-2018, 11:22 PM
Sprocket's Avatar
Sprocket Sprocket is offline
I went bare with mine, and then I saw someone who had painted theirs and the paint looked fantastic on the aluminum. Now I wish I had painted mine.
'70 GP Model J
462 Butler ported 87cc Edelbrock D-ports
RPM intake with Holley Sniper 2
CompCams 236/242 hydraulic roller
Tribal Tubes tri-y headers
TH400 13" Continental "Jim Hand Special"
3.50 9" CurrieTrac, 245/45-18 Front, 275/40-18 Rear
Old 09-29-2018, 11:44 PM
hgerhardt's Avatar
hgerhardt hgerhardt is offline
How about clear coat to keep them from turning gray? Mine still look like new after 19 years.
Old 09-30-2018, 02:39 PM
Sprocket's Avatar
That sounds like a good idea.
'70 GP Model J
Old 09-30-2018, 02:50 PM
ta man ta man is offline
All depends on ones build..I've seen some painted that look really good..and you have to look twice to realize they are aluminum..same with the intakes. I appreciate the stealthy look.
Old 09-30-2018, 03:11 PM
cnc's Avatar
cnc cnc is offline
Painted ...then go the extra mile and make your own casting numbers on the centre ports with some jbweld or something ....people look more than twice....lol....I know someone here that actually took a tool can't remember what it was called to give it the cast textured look as well...
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best 12.18@110.55 Lookin for 11's
Old 09-30-2018, 04:06 PM
Grand73Am Grand73Am is offline
I bet it was a "needle scaler".
Steve F.
Old 09-30-2018, 05:18 PM
cnc's Avatar
cnc cnc is offline
[QUOTE=Grand73Am;5938070]I bet it was a "needle scaler".
That kinda sounds familiar...
Old 09-30-2018, 08:57 PM
jeff chmura jeff chmura is offline
I like the bare look....Here is a pic of mine...... 461 KRE D ports.... Edelbrock 2x4's
ID:	494030   Click image for larger version
ID:	494031   Click image for larger version
Old 09-30-2018, 09:29 PM
Torquewar's Avatar
Torquewar Torquewar is offline
I have had the bare head look for 10 yrs and finally did the painted look.. Like it..my engine is all blue.
The E- head script removed and yes i used the needle scaler. Results came out nice. Used the same treatment on the intake.
TA man and CNC seen the car many times.
Old 10-01-2018, 09:39 AM
ponchjoe's Avatar
ponchjoe ponchjoe is offline
It all depends on the total look you are going for with your engine compartment in my opinion. Are you running an aluminum intake? If you are going for the stock sleeper look I’d paint all of it. If you are going with aftermarket valve covers, air cleaner, etc., I’d leave it all natural to show it off.
Old 10-01-2018, 01:04 PM
NeighborsComplaint's Avatar
Painted looks great until the paint burns off the exhaust ports. Clear coat will burn off too. Leave them bare.
Old 10-01-2018, 03:37 PM
Bob with the 66's Avatar
Bob with the 66 Bob with the 66 is offline
With finned covers, leave them natural.
Name:	Engine small 028_28.jpg
"Artificial intelligence is no match for natural stupidity".
1966 GTO Post Coupe, 467ci. N/A Pump gas, best 1/4 11.6 118mph
1966 GTO Post Coupe, "The Bright Idea" 535ci. N/A Pump gas, best 1/4 9.58 141mph
Old 10-01-2018, 10:29 PM
Tim Corcoran's Avatar
Painted if you want the engine to appear factory stock, otherwise bare
Tim Corcoran
Old 10-02-2018, 09:55 AM
track73 track73 is offline
To make a cast iron look on a 400 Chevy block I changed to 010, I used thinned "painted"JB Weld and matted it with 0000 steel wool.
1979 Trans Am WS-6 .030 455 zero decked
flat pistons
96 heads with SS valves
041 cam with Rhoads lifters 1.65 rockers
RPM rods
800 Cliffs Q Jet on Holley Street Dominator
ST-10 4 speed (3.42 first)
w 2.73 rear gear
__________________________________________________ _______________________________
469th TFS Korat Thailand 1968-69 F-4E Muzzle 2
Old 10-02-2018, 10:05 AM
78w72 78w72 is offline
high temp engine clear will not burn off the heads or the exhaust ports on aluminum heads. it doesn't yellow either & is pretty resistant to oil & fuel. a standard clear automotive body paint will of course burn off, but not the engine paint clears i have used.
i have e-heads & decided to clear them because i hate the chalky corroded look aluminum parts get after a short time... mine look like the day i did them after 5 years with dyno time, lots of drag strip runs & street miles. i also use it on aluminum intakes, valve covers, & other small parts under the hood. first set of valve covers i did 10 years ago still look like new!
just use a couple thin coats, not thick coats & it lasts very long & is easy to touch up if needed. ive also used the aluminum color engine paint & it lasts just as long as the clear on these kinds of parts... for iron heads, any paint will burn off the ports eventually & most very quick.
