Old 07-05-2021, 09:41 PM
bober bober is offline
Default light rust and slight pitting removal on chrome part of 87 cutlass original rally
Is there any easy way of getting this type of wheels cleaned up without scratching Chrome ? very light pits mostly . Thanks for any info ! I have to paint repaint around lug nuts between spokes yet .
Old 07-05-2021, 10:20 PM
694.1 694.1 is offline
Yes. Phosphoric or Oxalic acid..You will be impressed.
Still have my 1st Firebird
7th Firebird
57 Starchief
Old 07-06-2021, 12:44 AM
Entropy11's Avatar
Entropy11 Entropy11 is offline
Noxon metal polish works well (oxalic based). For heavier oxidation you can couple that with fine bronze wool. YouTube has videos of that combo specifically.
If there’s a ton of rust I usually spray with WD40 first to blast off the bulk oxidation so you’re not grinding it into the chrome with the bronze/noxon.
A final polish with Semichrome will usually take it that extra mile and also protect very well.
Everybody that does it often has their own routine… lol. That one is just my old standby.
Old 07-06-2021, 08:48 AM
nbn nbn is offline
0000 steel wool will clean up chrome and glass without scratching. Once you've cleaned the chrome, put a good coat of wax on it.
The Following User Says Thank You to nbn For This Useful Post:
Old 07-06-2021, 01:43 PM
tjs72lemans tjs72lemans is offline
I've also just used 0000 steel wool with good results.
Old 07-06-2021, 02:44 PM
JSchmitz's Avatar
JSchmitz JSchmitz is offline
X3. Also works on cleaning up old glass believe it or not.
Old 07-08-2021, 03:59 AM
4zpeed's Avatar
4zpeed 4zpeed is offline
0000 steel wool works but as mentioned some kind of protection is still needed.
Best I've found for a remover and protectant on pitted older chrome is Quik-Glo.
Edit - There are three formulas, https://quick-glo.com/?v=76cb0a18730b
Frank
Poncho Huggen, Gear Snatchen, Posi Piro.
