1970-71 TA Leaf Springs
When I ordered my leaf springs from Eaton for my '71 TA about a year and a half ago, I used their application chart which is based on the original GM blueprints since Eaton was the supplier. Their chart showed that the 1970 and 1971 Trans Ams used different springs on the left and right. One spring had about 3/4" more arc in it. Their chart also showed that the '72 and later TAs used the same springs on the left and right. Looking at NJSteve's thread, I thought it would be cool to detail my springs by spraying the factory part number on them. Steve was very helpful and emailed me some pictures to make the stencil with. As I started doing this I remembered having to order different springs for the two sides so I figured I would check the parts book. It showed 481612 as the spring number for L and R for 1970-72. .....hmmm.....is Eaton providing mis-information??....... As a second check, I dug out my original springs and, with some scuffing, was able to find the part numbers. Sure as heck, they are different and the one spring does have more arc in it. I am sure these are the original springs from my car. The one part number is 481612 PL and the other side is 482547 PM. I also noticed that the number font is smaller the Steve's '72 springs. Also, with all of the paint/overspray discussion going on, I will add that the bottom side of the spring has definite black paint on it from the VN black spray procedure, but the top side of the spring shows no evidence of any paint.
Just thought I would share this info with everyone.
1968 Firebird 400HO convertible 1971 Trans Am 4-speed, white/blue |
Check it out:
If you look closely at this upside down flipped photo of my original right hand spring you can see that they painted over a previous part number with a "2547 PR" still visible...under a larger PL painted code! Looks like we solved the mystery - they just reused and relabeled the earlier springs with a single part number! |
Couldn't find any paint marks on left spring.
The car sat perfectly level with the original factory front and rear springs and I re-used them after dissassembling, cleaning and reassembling them. There's nothing like the original GM parts (when they're not worn out). The one thing I can't stand is seeing these cars sitting at some crazy four wheel drive ride height with 6 inches of wheel well visible over the top of the tires. |
No offense meant, Sir.
I didnt mean to pick on your car. :-) |
Just tonight I was flipping through the 1971 Firebird Assembly Manual and checked the rear suspension section. There it was, rear leaf spring for WS4 right-482547 left-481612.
Norwood, that doesn't look as bad as some I've seen with replacement rear springs. Kind of has a more period appropriate slight forward rake.
But ditto the "sky-high 4x4 attitude (altitude) of some "correct" restos. Especially with the rocker to ground clearances given in the Shop Manuals.
Ric, Mine is not as obnoxious as some but still sits WAY higher than before I changed them
Hey Norwood, I didn't think it looked that bad either but it may be that I love those blue cars so much my eyes keep drawn to look at other parts of the car, lol. I too hate the look you guys are talking about. Seems about once or twice a month I'll look at a TA on ebay with the afore mentioned 6" between tire and fender whell. It just ruins the entire look of the car.
Since we're talking about this does anyone know what that distance should actually be? The distance between the top of the tire and the fender lip? I think my '73 looks good but I've been thinking about dropping it 1" all around as I've seen a few dropped a 1" tp 1.5" and think it looks great.
Jimmy www.firebirdgallery.com 2002 WS6 M6 Trans Am - original owner 1973 Trans Am 455/4-speed 1971 Formula 400/400 1969 GTO 400/400 - 3rd owner 1968 Firebird Convertible 350/200R4 POCI - AAC |
Craig got me thinking maybe I need to go & take a straight side shot pic of my Blue '70 to see how it compares with his. Then I remembered,....................it's up on blocks for the winter!! DOH!!
Doesn't look bad to me either.......that being said, I re-used my original front coils and re-arched the rears. It now sits a little too high in the back.
Which spring has more arc in it? The left side or right side? I have both springs disassembled and ready for resto. Definitely a 3/4 difference in the arch. I can faintly see painted on part#'s, however not clearly. Any help would be awesome on this one. Thanks
DS for the bigger arch. Try to get the other leafs tested and make a similar "pack" for each side.
GM Changed the upper control arm mounting Arms ( steering) and the rear leafs to accommodate new Road crowns, and Radial tires. There was no longer a need for a difference in springs as alignment and radials could make up for it. I always put on 1973 ( single part number) 4 leaf , around 126 lbs springs. This allows some movement, even with the rubbers in the eye and shackles. Firebirds are always heavier on the DS, so Big arch there. |
Thanks for the follow up
Awesome! Thank you for the info. I did have another question and most likely many more. Are there any suggestions on retaining clips for leaf springs as to where I can purchase? Thought I noticed on some other threads that there were a couple members who actually produce them?
