Old 10-10-2021, 11:48 AM
OCMDGTO's Avatar
OCMDGTO OCMDGTO is offline
Cool build and I'm curious to hear how it does in the car.
Chris D
Old 10-10-2021, 12:58 PM
Pontiac Performance Author
I would expect more HP out of 248/253 cam. I think Steve25 is correct with his 450 estimate. Extrapolating the torque curve, I would guess a peak of 3600 to 3700 at 558 to 586 torque. what brand dyno was he using. We pulled down to 3000 with the SuperFlow 901 with 697 peak torque.
Old 10-10-2021, 01:23 PM
taktikian taktikian is offline
Ken It was a Superflow but I do not know what # superflow. He tried to adjust it to obtain a lower rpm pull but he said it just made it worse. I agree. I was also expecting 450 h.p.. Down about 15 hp. Do you think a properly running Q-jet would have made up that difference? Thanks,Paul
Old 10-10-2021, 01:31 PM
Question What dyno
Ken, On the paperwork I am now looking at it says " Super Flow WinDyn V3.2 " I don't know if that tells you anything I know little about this.
Old 10-10-2021, 04:16 PM
PAUL K's Avatar
PAUL K PAUL K is offline
Here is the dyno sheet:
Go fast, see Elvis!
Old 10-10-2021, 04:58 PM
Dragncar Dragncar is offline
Originally Posted by Skip Fix View Post
For all those that think 4 hole adapters to Q jet intakes "kill flow" personal at track experience. San Antonio track my 455 with E heads small roller had a 72 HO intake and a Brad Urban 73 SR SD Q jet 800cfm that ran good to keep the Shaker until I modified an extra base to clear the Holley/Demon bowls(front a BFH rear esp Holley I grafted a piece off a cheap drop base air cleaner). So at the track swapped an adapter and an 850 DP Demon out of the box the idle was right on and it picked up 0.2 seconds an 3 mph. So I guess it did not hurt flow that much. Eventually swapped on a Torker II that picked it up a bunch.
I do not know about "kill flow" but they can not help. I know of some on street engines and they run "OK".
If one had a dyno session using a RPM intake with a 850 DP but made a pull using one of those pinch down adapters and then made pulls with a std 4 hole you would get a better idea what they cost in terms of horsepower.
This is a very cool build and i was wondering if that adapter cost him the 15 HP more it should have made.
It might have.
Old 10-10-2021, 05:26 PM
Vengeance Race Engines's Avatar
Vengeance Race Engines Vengeance Race Engines is offline
Originally Posted by taktikian View Post
I think I know what you are going to say but what HFT cam do you think would have been preferable?
A profile more suited to the application and rpm range. In YOUR engine, with 9.5 compreasion and those lobes, that 112 is hurting you. With Edelbrock heads , a single pane and 10.5 compression, it would be a different conversation. That cam wants to shine up top, and can't due to heads and intake, so torque drops like a stone. If 5500 rpm is what you were after, a profile more suited to work there would have yielded better results. Not knocking what you have. Just an observation.
Old 10-10-2021, 06:25 PM
pastry_chef's Avatar
Well I finally got my 455 on the dyno. I will list its' components and tell me what you guys think. 455-40 over, unmolested 1970RAIV 614 heads, Crower 60245, Dougs headers 9.5 compression ,original 1970RAIV intake , engine builders 950 Holley
Rocker ratio?
Old 10-10-2021, 06:27 PM
steve25 steve25 is online now
Windyn is just the Superflow computer program for the dyno.
Run it as is for now and see if you want more top end and if so take 2 degrees of that 4 out of the cam.
Old 10-10-2021, 06:32 PM
Similar power from this 455
http://forums.maxperformanceinc.com/...d.php?t=802889
Old 10-10-2021, 06:37 PM
Stan Weiss's Avatar
Paul,
Thanks for the dyno sheet. That seems like a strange fuel usage curve. Any idea why?
Stan
Pontiac Pump Gas List
The Following User Says Thank You to Stan Weiss For This Useful Post:
Old 10-10-2021, 06:40 PM
1.65 rockers used
Old 10-10-2021, 06:47 PM
Paul,
Stan
I think carb way too big. Thinking of trying to get the SMI functional and do away with adaptor plate. Don't ask me the cost of the Holley he slapped on-it is embarassing but I am the one who said go ahead so it is what it is.
Old 10-10-2021, 06:59 PM
Thanks for your input. I have run the HO Racing HC-03 (244/252) in the original 400 iteration and did find that it really woke it up from the original 041 cam. I assumed this cam would be analogous to what I have already run
Old 10-10-2021, 10:32 PM
I doubt the carb size hurt the numbers. If anything the 950 size probably helped a bit up top and wasn't run low enough to matter. In reality all that comes into play with drivability anyway, and that's not something that can be determined on an engine dyno.
I've seen those 950 carbs on 350's on up over 500ci, they are pretty versatile. Once jetted properly for the combo they work pretty well.
I think you did well for the combo you have. I personally would have liked to see more compression with that cam, or maybe a cam more suited to the compression you have, but overall it's not bad and should be pretty fun once in the car. Plug it in and enjoy it.
https://youtu.be/XqEydRRRwqE
Old 10-10-2021, 11:04 PM
Len Williams 455 with stock heads rated about 425 HP.
http://www.lenwilliamsautomachine.co...ong_Block.html
Seems stock intake / heads are the bottleneck around that power level.
The Following User Says Thank You to pastry_chef For This Useful Post:
Old 10-11-2021, 08:44 AM
PAUL K's Avatar
Fwiw
https://forums.maxperformanceinc.com...errerid=134156
A RAIV head and manifold flows considerably better and has a larger port volumes.
Go fast, see Elvis!
  #38
Old 10-11-2021, 08:51 AM
A RAIV flows considerably better, has a larger port volume and the manifold has larger rumeers.
I've seen around 200 CFM intake side listed for stock, it that correct?
http://www.wallaceracing.com/ultimateflow.htm
  #39
Old 10-11-2021, 10:33 AM
PAUL K's Avatar
Not for a RAIV., 240 would be close
Go fast, see Elvis!
  #40
Old 10-11-2021, 12:00 PM
Jay S's Avatar
Jay S Jay S is offline
FWIW…Here are one of my friends 614 bone stock flow numbers with the stock original valve job. I think they likely vary more than the d ports though. It has been said there are some 250 cfm bone stock ra4 heads around.
