Old 10-09-2023, 04:25 PM
bhill86's Avatar
bhill86 bhill86 is offline
Default ID these valve covers?
Anyone recognize these valve covers? The assumption was they’re for Pontiac, and I haven’t tried them on my spare engine yet, but they don’t look like they’re deep enough compared to factory valve covers. The odd shape on each end puzzles me also. Any clue?
1977 Trans Am 400/4speed (swap)
Brian
Old 10-09-2023, 04:27 PM
misterp266's Avatar
The only “odd” thing I see is the two screws in the top one.
" Darksiders Rule "
Old 10-09-2023, 04:33 PM
steve25 steve25 is online now
Well there pre mid 1967 in the latest because those shallow valve covers would only work on the early valve inclination angle heads.
How far back you might ask?
My guess is that the first chrome valve covers Pontiac used would have been on the 64 GTO.
Stuart's Avatar
Stuart Stuart is offline
That shape valve cover was used by the factory from 1961 up to I think 1966. I'm not sure about the exact year, I'm not familiar with the extended breather on the one. I agree the first factory chrome covers would have been in 1964, but these could have been plated by some previous owner.
The Following User Says Thank You to Stuart For This Useful Post:
Old 10-09-2023, 04:46 PM
madeuce50's Avatar
madeuce50 madeuce50 is offline
If they are a factory chromed set, then pre February of 1964 model year. Pretty sure 64 was the last stacked passenger side cover and sometime early in calendar year 64 the solid [no hole] drivers side cover was superseded to one with the 1" hole.
Old 10-09-2023, 05:00 PM
thepontiacman's Avatar
Pontiac earlier than 67 had those bumps on ends.
Sent from my moto g power 5G - 2023 using Tapatalk
Old 10-09-2023, 05:37 PM
The Champ's Avatar
1964 Pontiac Dealers Sales Manual page with 4bbl and tri carb engine showing those valve covers and my original 1964 GTO 78XW block date coded 4/11/64 with said valve covers:
Name:	GTO Option 4.jpg
ID:	621342   Click image for larger version
Name:	78XW Complete 1.jpg
The Following User Says Thank You to The Champ For This Useful Post:
Old 10-09-2023, 05:38 PM
Held for Ransom's Avatar
Held for Ransom Held for Ransom is online now
Butler sells the '66 style, but doesn't have a removable top like the one seems to (wait, it's an illusion).
https://butlerperformance.com/i-2674...aau-n221t.html
Mr. Gasket has an extension tube...
https://www.ebay.com/itm/195943695894
The Champ, oil hole looks centered on his.
So long, farewell.
Old 10-09-2023, 05:57 PM
Oops, looks like that's the vent tube hole.
This one on eBay doesn't have the hole and an extension, listed as '64.
https://www.ebay.com/itm/393918595455
This one is listed as 1959-'64 and has the hole.
https://www.ebay.com/itm/234410865613
So long, farewell.
Old 10-09-2023, 06:14 PM
They’re 1964 GTO valve covers.
I have a set on my 1964 421 HO.
Don’t use them on 1967 and later 14 degree valve angle heads unless you use some spacers, their shallow design is correct for the 1966 and earlier (and low-performance 1967) 20-degree 326/389/421 heads.
ID:	621345   Click image for larger version
ID:	621346   Click image for larger version
Old 10-09-2023, 07:21 PM
bhill86's Avatar
Thanks for the info guys. I don’t plan to use them. They were just part of a parts stash I got. What are the bumps for anyway? Anything or just aesthetic? If they’re of use to someone they can find their way out of my garage cheap.
Brian
Old 10-09-2023, 10:51 PM
NeighborsComplaint's Avatar
Triple Black 1971 GTO
Old 10-09-2023, 11:01 PM
Originally Posted by NeighborsComplaint View Post
1959-64
The 1964 GTO chrome passenger side cover was unique with that tall breather stack. California emissions version used a push-on ‘top hat’ to fill the oil and a breather tube connected to the side of the air cleaner or Tri-Power air cleaner bases to the driver’s side valve cover. The 49 state cars used a push on breather cap on the passenger side only.
Here’s what 1959 & 1960 valve covers look like, completely different than the ‘61 - ‘66 covers.
No pentroof at the one end and just shaped differently. Twist-on oil filler breather caps located in the center and front.
Pictured is the 1959 2-barrel 280 hp 389 that I was playing with and have since sold, note the reverse cooling setup that was discontinued for 1960.
Also pictured 1964-1965 Tri-Power CA emissions air cleaners and breather pipe and 1964 only CA emissions push-on ‘top hat’ oil filler cap. Finally the 1964 only 49 state push-on chrome oil filler breather cap.
ID:	621396   Click image for larger version
ID:	621397   Click image for larger version
ID:	621398   Click image for larger version
ID:	621399   Click image for larger version
Old 10-10-2023, 10:41 AM
pfilean's Avatar
pfilean pfilean is offline
Those little bumps at the ends are a puzzle. Have never heard any explanation for them. And can't see any benefit to them either. Showed up I think 1960 when the reverse cooling was gone and there shouldn't have been any connection. And disappeared maybe 1967 or possibly whenever the paint color changed to the metallic blue.
Old 10-10-2023, 11:53 AM
Keith Seymore's Avatar
Me neither.
I meant to ask Mac about that but sadly he passed before I had the chance.
K
'63 LeMans Convertible
'63 Grand Prix
'74 Chevelle - original owner, 9.85 @ 136 mph besthttp://www.superchevy.com/features/s...hevy-chevelle/
Old 10-10-2023, 12:56 PM
bhill86's Avatar
Good info nonetheless. I learned something new.
Brian
Old 10-10-2023, 01:03 PM
Engine paint color change to metallic blue happened for the 1966 model year that still had the same valve covers as 1965 which used the 1959-1965 light blue paint so no correlation there.
Could be simply for the sake of styling not function that the pentroof stamped at the end was put there, they’re an interesting looking valve cover for sure.
Old 10-10-2023, 07:11 PM
Mister Pontiac's Avatar
Mister Pontiac Mister Pontiac is offline
Well after all, they're Pontiac. And Pontiac is "Cool..."
The only other thought that came to mind is some amount of 'rigidity' to the entire cover?
If I had a 64, I'd run 'em. Original design just looks right.
Eric "Todd" Mitten
'74 Bonneville 4dr Sedan (455/TH400/2.93 open)
'72 LeMans GT (455/M-13/3.23 [8.5"] posi)
'71 GTO Hardtop (400/TH400/3.07 12 bolt posi)
‘71 GTO Convertible (455HO/TH400/3.23 posi)
'67 GTO Coupe (455/ST-10/2.93 posi)
'67 Tempest Wagon (428/TH400/2.56 posi)
Deuteronomy 8:3
Old 10-10-2023, 07:23 PM
tom s tom s is online now
61 was the first year with the pentroofs.Tom
Old 10-10-2023, 09:14 PM
GtoFM's Avatar
GtoFM GtoFM is offline
Ames shows the valve covers in the OP as '64 EARLY. The LATE covers have a hole in the left cover. Midyear an executive decision must have been made, probably by someone on the line, to just use Cali covers and plug the other 49 states. Thoughts?
bhill86, what ARE the 2 screws securing to the top of the driver side VC?
