Dual gate His/Hers shifter install question
Planning to switch over my automatic on the floor in my Lemans to a dual gate his/hers shifter made for my 67. Does anyone know if the linkage is the same between these two shifters as I'm hoping to be able to use my current linkage as the dual gate is not coming with any linkage. Also, if anyone has ever made such a swap and has any other advice or issues to be on the lookout for, I would appreciate your thoughts.
Thank you, Sloan |
They make a cable for the shifter. I bought one but it is a tad too long and doesn't work right. I understand that there are two versions of the repro cable and the more expensive one is correct.
Hopefully someone else will chime in with more info. You didn't say what transmission you have so I am guessing it's a TH400.
Scott If you always do what you always did You always get what you always got |
i know if i rememeber correct the cable for the dual gate is specfic to that shifter
Thank you all for your help and the web site. Exactly what I needed.
