#41
Bull Nose Formula-461, 6x-4, Q-jet, HEI, TH400, 8.5 3.08, superslowjunk Last edited by Blued and Painted; 04-26-2013 at 10:30 AM. |
#42
Don't get me wrong, I am most definitely building this motor with performance in mind. I want it to be as fast a manageable street engine as possible. BUT, if given the CHOICE, between two cams....I will chose the one with the most aggressive idle.
1965 TriPower GTO, 1967 GTO, 1969 GTO, 1969 Judge, 1972 GTO, 1977 Smokey and the Bandit, 1989 TA ProStreet, 1968 Firebird NHRA 10.90 racecar, 1963 Tempest S/Gas |
#44
I would go with Kevin's custom cam lobe selection , except I would spread it out to 112-114 lobe sep to compensate for the ex man restriction and some of the exhaust stream crosstalk that dilutes intake mixture in adjacent cyls. Yes , I know the SD man. has divided runners-but being so short, there is still crosstalk.
JD , you can call anytime to discuss.
GOOD IDEAS ARE OFTEN FOUND ABANDONED IN THE DUST OF PROCRASTINATION |
#45
On a side note, I don't think there is anything wrong with wanting your car to sound a certain way. As long as it still runs HARD! When you are behind the wheel and your 06 corvette or cobra is idling like a sewing machine, it just doesn't feel the same. Just my opinion.
Sandoval Performance www.sandovalperformance.com Pontiac Crate Engines CNC Edelbrock heads Custom Ground Cams JOHNSON Limited Travel Hydraulic Roller Lifters Last edited by paul s.; 04-26-2013 at 09:14 PM. |
#46
Glad to see you entered the discussion, Mr Crocie. I have read many articles featuring your engines and found them very informative.
Sandoval Performance www.sandovalperformance.com Pontiac Crate Engines CNC Edelbrock heads Custom Ground Cams JOHNSON Limited Travel Hydraulic Roller Lifters Last edited by paul s.; 04-26-2013 at 09:13 PM. |
#47
#48
Well there you go then.
#49
That kid always tries to have the last word !
