Old 05-12-2010, 10:08 AM
79TA455STROKED's Avatar
79TA455STROKED 79TA455STROKED is offline
Default NEW BEST AND IN THE 9'S!!
Went to track on mon for a rental with some buddies.
New 4.30 gears got the 60' time down to consistant 1.38s and 9.81 ets at 138mph.
1/8th mile was 6.2's at around 110mph.
Last tire gear combo was 28' tire with 3.73 gear and best was 10.18 at 134
Now it is 4.30 gear with a 315 m/t drag radial (30").
Think there is still some left in it!
This is all motor,pump gas.still 11.3:1 comp,468 c.i 455 block
Was shifting at around 7300rpm,went through traps at around 7000-7100rpm.
Ill get some vid up.
9.81 at 139.89mph
3400lbs
Butler 468,11.3:1 comp,N/A,PUMP 93 OCT GAS!
370cfm butler eheads
port matched victor
1095 king demon
4.30gear,th400
MICKEY THOMPSON DRAG RADIAL tire
Old 05-12-2010, 10:24 AM
Keith Seymore's Avatar
I'm jealous.
Congratulations!
K
'63 LeMans Convertible
'63 Grand Prix
'74 Chevelle - original owner, 9.85 @ 136 mph besthttp://www.superchevy.com/features/s...hevy-chevelle/
Old 05-12-2010, 10:27 AM
grandville455's Avatar
grandville455 grandville455 is offline
Excellent! Congrats!
Darby
74 Grandville 2Dr 455 c.i 4550#
2011 1.60 60 ft,7.33@94.55-11.502@117.74
2017, 74 firebird -3600 lbs (all bests) 1.33 60 ft, 6.314@108.39 9.950@134.32
M/T 275/60 ET SS Drag Radial
2023,(Pontiac 505) 1.27 60 ft, 5.97@112.86, 9.48@139.31.... 275/60 Radial Pro's
twooldgoats's Avatar
twooldgoats twooldgoats is offline
Congratulations. That's a big milestone.
Jim
****'63 Tempest, 475" IAII, Wenzler Super Chief heads, converted to blown alcohol, Birdcatcher, Littlefield 10-71 high helix. Best pass to date: 7.67 @ 181.59 (1/4 mi.), 4.95 @ 143.67 (1/8 mi.), 1.18 (60 ft)
7.75 @ 178 pass:
https://www.youtube.com/watch?v=Iez3...ature=youtu.be
First seven second pass(7.98): https://wwwoutube.com/watch?v=DK17...ature=youtu.be
Thanks to Paul Carter @ Koerner Racing Engines
Old 05-12-2010, 10:28 AM
Gach's Avatar
Gach Gach is offline
Congrats! on getting in the 9's I knew you get there.
Old 05-12-2010, 10:34 AM
Ron H's Avatar
Ron H Ron H is offline
Good job. Glad you are making progress.
68 Firebird
Are you running with the wind or breaking it?
Old 05-12-2010, 11:01 AM
triathlonx13's Avatar
That's a huge jump ! What is your stall ?
Great Job !
Old 05-12-2010, 11:03 AM
blue66ss's Avatar
blue66ss blue66ss is offline
NICE!!!!
Old 05-12-2010, 11:12 AM
fast72lemans's Avatar
fast72lemans fast72lemans is offline
Send a message via MSN to fast72lemans
Congrats on the new best!
Mark
Old 05-12-2010, 11:15 AM
Great Job !
Thanks everyone!!
Still same converter,a 9" continental,stalls at 4800rpm on transbrake.
Slip comes in at around 6%.
I was leaving off a 2 step,worked my way up to 4600rpm leave.
60's were consistant 1.38s all day.
Old 3.73 gear/28" tire combo was doin 1.53 60' but thats was leavin off a 1500rpm footbrake.
Gonna look to see how i can drop 60' lower then 1.38,i think there is more et in it with the 138mph.
Also cldnt look at afr logs till i got home and found out i was way lean at 13.5-13.7 afr! so maybe a little power left in it to!
9.81 at 139.89mph
3400lbs
port matched victor
1095 king demon
4.30gear,th400
Old 05-12-2010, 11:37 AM
Forgot to mention,this was also with leaving the full exhaust including tailpipes on car at track.(3.5")
9.81 at 139.89mph
3400lbs
port matched victor
1095 king demon
4.30gear,th400
Old 05-12-2010, 11:43 AM
BADDTA's Avatar
BADDTA BADDTA is offline
let's see pics of the car with the 315 DR's
Old 05-12-2010, 11:54 AM
ponjohn's Avatar
ponjohn ponjohn is offline
Awesome!!
Cage yet?
Old 05-12-2010, 11:59 AM
Ill get some vid up so u can see tires,figuring out how to get it off vid camera!lol
Still no cage!
9.81 at 139.89mph
3400lbs
port matched victor
1095 king demon
4.30gear,th400
Old 05-12-2010, 02:04 PM
slowbird's Avatar
slowbird slowbird is offline
Great run Congrats!
It is amazing how close are cars are setup. I have a 9" Continental, same gear, same size tire, 3.5" exhaust. I hope my 60fts as good as yours does.
Old 05-12-2010, 02:07 PM
Here is a couple of vids...
9.81 at 139.89mph
3400lbs
port matched victor
1095 king demon
4.30gear,th400
Old 05-12-2010, 03:18 PM
FWIW, an old table I have which has proven very accurate in my experience, shows @ 138 MPH an ideal chassis setup would yield a 1/4 mile ET of 9.75, 1/8 mile ET of 6.17, 330' of 3.96 and a 60-foot of 1.34. If so, it would mean you do have a little more there, even at your current power level. And, if your MPH goes up, even more room for improvement.
Again, great job! That's a huge change from tires and rear end ratio. Gets me to thinking.
Jim
7.75 @ 178 pass:
Old 05-12-2010, 03:48 PM
Gach's Avatar
It's amazing what a little tweating dose. Right gear...getting the converter
right and a little money, to do these things. Yeah I believe there's another tenth
or two there.
Old 05-12-2010, 04:06 PM
455-4+1's Avatar
455-4+1 455-4+1 is offline
Sounds great in the burnout, well done !!!
Working on going faster (and now staying dry at the same time !!)
Old 05-12-2010, 06:39 PM
ponjohn's Avatar
It would be interesting see if the ET improved with the addition of a cage, even though you're adding weight.
