Can anyone help to ID an intake manifold that I have?
It has the numbers 532422 GM1 by the back carb. I thought it was for early Pontiac as it does not look like it would fit 389/400 block. Has along gooseneck for the water intake. Is this a performance item that people would be interested in? It has some carbs, but they the middle one doe not look quite right. Thanks Reed |
Reed, You have a 1959 389 tri-power manifold. Yes, Someone somewhere needs that intake. The carb. numbers are: (F) 7013063 (C) 7013067 (R) 7013065 Floyd Hand
Thanks for that info. I am correct that this 389 is different from the later 389's right?
Yes you are correct.
Try calling CRUSHPROOF! 512-386-9889 |
