Old 03-21-2000, 06:33 PM
64cat's Avatar
64cat 64cat is offline
How do i remove the rear molding at the bottom of the rear window and the pieces that wrap around to the back windows on a 1964 Catalina? I want to check the condition of the metal under it. Thanks for the help.
Karl Madcharo
1964 Catalina
Tucker, GA
64cat's Avatar
Karl Madcharo
1964 Catalina
Tucker, GA
Old 03-24-2000, 11:02 PM
Blackcat's Avatar
Blackcat Blackcat is offline
Bonker's-T-Cat Moderator
The window trim is held in place with metal clips. These clips hook on to the trim on the underside. You need a window trim remover. This tool is available at most auto
parts stores. I would practice on a car in a junkyard first before attempting yours. The clips are spaced the same distance apart on both sides. Using the tool pry the clip back and the trim should pop up ( note should) Do not pry with a screwdriver. Don't pry up on the trim. You might bend it.
Mr. Z
Try calling CRUSHPROOF! 512-386-9889
