Old 08-09-2008, 10:00 AM
Mike S's Avatar
Mike S Mike S is offline
Default Is T-brake any faster?
I have been running a 10.00 index race. I am having problems going 10.00 in the heat of the summer. Best I can muster is 10.09. I have a t-brake but haven't been useing it. Will I go quiker with the t-brake launching at 3500? I have been foot brakeing at 2000 and cutting .030 lights on a .500 pro tree. Do you thing I will red light leaving on the brake?
Thanks Mike
Old 08-09-2008, 10:57 AM
Ron H's Avatar
Ron H Ron H is offline
You may hit the tires harder and improve the 60's and possibly run better ET as well. For certain you will be more consistent launching with the transbrake over footbraking.
68 Firebird
Are you running with the wind or breaking it?
Old 08-09-2008, 11:10 AM
67Beast's Avatar
67Beast 67Beast is offline
You should definately be quicker with the brake. I run 6.50 index on 1/8th mile track. I can footbrake the car in the heat and run high 6.50's. On the brake leaving at 5000 it runs 6.50 dead on. As the track cools the car picks up to 6.30's. Time to work the brake and throttle.
Old 08-09-2008, 12:08 PM
Jagtec1's Avatar
Jagtec1 Jagtec1 is offline
Most people I have talked to have not picked up any ET with a brake. They are able to hit the tree better though. I would like to try it out and see...need to put a brake in first though!
Darin
'64 Bonneville Wagon (sold)
69 Lemans-All motor (sold)
9.81 @ 136.39MPH
Old 08-09-2008, 12:11 PM
79TA455STROKED's Avatar
79TA455STROKED 79TA455STROKED is offline
Improves my 60' from 1.53-1.54 to consistant 1.50's.
I leave at 3500rpm off the brake.
9.81 at 139.89mph
3400lbs
Butler 468,11.3:1 comp,N/A,PUMP 93 OCT GAS!
370cfm butler eheads
port matched victor
1095 king demon
4.30gear,th400
MICKEY THOMPSON DRAG RADIAL tire
Old 08-09-2008, 02:17 PM
JKrull66's Avatar
JKrull66 JKrull66 is offline
Send a message via AIM to JKrull66
Live a little.... leave off the T brake at 5200 and watch the clouds go by...
John
Beers Bikes Babes and Pontiacs Rule!!!
63 Lemans in the 9's race
66 GTO HT Cruiser
06 Triumph Rocket III TURBO! 2300 CC Bad boy
KTM 525 Dirt Terrorizer
POLARIS 900 RZR
10 GMC SLT Duramax Haul anything anywhere
http://www.facebook.com/profile.php?...app_2392950137
Old 08-09-2008, 03:25 PM
estep455's Avatar
estep455 estep455 is offline
John
you said a mouth full there. im still repairing damage from going on the bumper after leaving at 4800 off the brake!
Old 08-09-2008, 03:30 PM
n20ta2's Avatar
n20ta2 n20ta2 is offline
I picked up a decent bit off the brake,I was running an interupt relay from the brake to the spray and took the rear bumper cover off my t/a,must have looked cool but it cost me 1000 bucks for a cover and 1 new header.
1969 GTO street strip project 11.1 forged 461, highport heads
1995 Trans-am 420 ci sb 14:1 compression 9"ford
9.89@132 1.34 60ft SOLD!
Old 08-09-2008, 06:43 PM
mikeb mikeb is offline
I've been itching to try my t-brake but I have a worked over eaton posi unit in the back on slicks, and I expect the posi unit would cry uncle on the first launch. Any of you guys running posis, or are all of you on spools (with slicks)?
Old 08-10-2008, 12:25 AM
n20ta2's Avatar
9" with a spool
