Old 12-04-2022, 10:01 PM
CraigG.'s Avatar
CraigG. CraigG. is offline
Default 67 through 70 Pontiac blue metallic engine paint
Hey everybody,
What are Reasonably priced fiz can options for 67 through 70 Pontiac metallic blue engine paint?
Thanks, Craig
Old 12-04-2022, 11:39 PM
ZeGermanHam's Avatar
Pontiac began using the silver blue metallic starting in 1966. I used Dupli-Color DE1616 on my car.
1998 BMW 328is (track rat)
The Following User Says Thank You to ZeGermanHam For This Useful Post:
Old 12-05-2022, 01:36 AM
Dick Boneske's Avatar
The Duplicolor DE1616 I've used in the past have all been too silver with too little blue. I have heard they changed the formulation for this and the DE1610 '59-'65 engine color.
I have had zero problems with Ames and Inline Tube versions of both colors. Problem is, they're double the cost of Duplicolor.
BONESTOCK GOATS
'99 Bonneville SE Sedan
Old 12-05-2022, 01:38 AM
Here's a '66 I restored that has, what I believe, to be the correct color.
Name:	Barry's '66 Tripower 001.jpg
BONESTOCK GOATS
Old 12-05-2022, 08:27 AM
F ROCK's Avatar
F ROCK F ROCK is offline
Unhappy
That Duplicolor silver/blue conducts electricity really well.
Ask me how I know...
Old 12-05-2022, 09:25 AM
grivera's Avatar
grivera grivera is online now
Could be the picture but the DE 1616 color in post #2 is less silver-ish than the the factory color in post #4.
Will Rivera
'64 LeMans 400/461, #16 Heads, HR 230/236, TKO600, 9inch Rear, 3.89 gears
Old 12-05-2022, 09:43 AM
Ebay !!
Old 12-05-2022, 10:01 AM
redbird68's Avatar
redbird68 redbird68 is offline
I have always used Bill Hirsch. I brush instead of spray, one quart will do an engine. does not look as 'blue' as yours but could be lighting. I like it regardless.
birds, goats and a few outliers
Old 12-05-2022, 11:07 AM
I get it right off the shelf at Napa and it matches, looks, perfect to me and everyone else that sees it.
https://youtu.be/XqEydRRRwqE
Old 12-05-2022, 11:27 AM
Tim Corcoran's Avatar
Inline Tube has a special blend they had made up. They sell it to Butler and Ames and others it seems to be the most correct according to Butler Performance. I just used it on this engine. I have been unable to find the Dupli color paint in this color anywhere.
Tim Corcoran
Old 12-05-2022, 11:43 AM
JUDGE3 JUDGE3 is offline
Default 16 r'
yepper DE1616
good choice! metallic blue is the only color that should be on a pontiac engine.
Old 12-05-2022, 11:45 AM
Agree. Although the paint in post #4 is not "factory", but rather is whatever paint Dick used to restore the intake manifold in his photo. Regardless, the paint in Dick's photo does appear to be more silver than blue when compared to the Dupli-Color DE1616 shown on my engine in post #2.
You bring up a good point. I bought a case of 6 Dupli-Color DE1616 cans from Amazon in May of last year for $42.35. Looking for them now, I can't find anything, anywhere. Not available on Amazon, eBay, or at O'Reilly... Wonder what's going on.
Old 12-05-2022, 11:47 AM
grivera's Avatar
My local Napa has ordered Duplicolor 1616 for me on more than one occasion for no extra charge. Also, Advance Auoto and Autozone can order it for you. All of these for in store pick up.
Will Rivera
Old 12-05-2022, 02:24 PM
Yeah Will, that was then this is now and no one seems to have it. I think Dupli Color stopped making it but at least you can get the stuff that Inline Tube has.
Tim Corcoran
Old 12-05-2022, 03:25 PM
jhein's Avatar
jhein jhein is offline
As was mentioned, according to Butler, the Inline Tube color is what they think is best, and the Duplicolor is their second choice.
I went with the Bill Hirsch initially and I did not like it at all. The Duplicolor DE1616 looks much, much better to me. I got it from Summit a few weeks ago but it's not available now.
Hirsch:
DE1616:
70 TA, 467 cid IAII, Edelbrock D-port heads, 9.94:1, Butler HR 236/242 @ .050, 520/540 lift, 112 LSA, Ray Klemm calibrated Q-jet, TKX (2.87 1st/.81 OD), 3.31 rear
Old 12-05-2022, 04:17 PM
Do you have a local Napa? Ours carries that Pontiac duplicolor on the shelf.
Old 12-05-2022, 05:29 PM
grivera's Avatar
Just called my local Napa - 3 cans of 1616 on the shelf but none available for order. Interesting thing is the system defaults to the 1610 sky blue
Will Rivera
Old 12-05-2022, 07:31 PM
Jeff Hamlin's Avatar
Thumbs up DC 1616 Hands Down.
Been using it on all my OHC builds for years and it lays out really nicely and holds up well.
Even when I spray parts separately and sometimes from different lots it always matches up really well.
I still have some PK 227 and it always looked too green to me.
ID:	603114   Click image for larger version
ID:	603115   Click image for larger version
Name:	1966 OHC 4BC BUILD 1 (135).jpg
ID:	603116   Click image for larger version
Name:	1966 OHC 4BC BUILD 1 (90).jpg
ID:	603117   Click image for larger version
Old 12-05-2022, 07:37 PM
CraigG.'s Avatar
Thanks Guys,
I ordered the DE1616 from NAPA - I hope they can get it.
I will let you know.
Take care, Craig
Old 12-05-2022, 08:39 PM
tjs72lemans tjs72lemans is offline
I have one can of Valspar Plasti-Coat in the silver blue high temp. Can says OER and cap color is blue I wanted for my 72. One spray and I knew what the cap color looked like wasn't what came out. I took the second can back to the parts house and got a different brand that was what I needed. So, this can I would sell cheap.
