Old 08-18-2022, 05:30 PM
64speed's Avatar
64speed 64speed is offline
Default Dead spot at idle
If I roll the throttle on to gain speed from a stop my car runs great. I have noticed today while playing around that if I just floor it from a dead stop it bogs and cuts off. Where do I start?
Old 08-18-2022, 05:52 PM
25stevem's Avatar
25stevem 25stevem is offline
I thought you just had the car. other then belts slipping very much to your liking just two weeks ago!?
I do stuff for reasons.
Old 08-18-2022, 05:56 PM
64speed's Avatar
I have been driving the car thru break in and working the kinks out. I have changed all break in fluids and am now finally reaching the point to where I can beat on it a little
Old 08-18-2022, 05:59 PM
Jim Moshier's Avatar
it sounds like the squirters are not working. and when you roll into the throttle it's okay, but when you stab it goes lean. pull the air cleaner and start the car and accelerate the throttle and see if the squirters are working, if not an easy fix is to order an accelerator pump assembly from Cliff Carb.
Jim
Jim Moshier
1962 Catalina 389
Old 08-18-2022, 06:15 PM
64speed's Avatar
I have not been able to just drop the hammer from a dead stop because my builder, quick performance, and American Powertrain all told me to go easy the first 500/1000 miles. I have romped it from a roll a little but I have never just put it in first and dropped the hammer. I have passed those mileage milestones a while back and I changed all my fluids front to rear, greased everything, made sure all ujoint bolts etc were tight and went to a stretch of deserted highway. Did a few rolls like I have been with a little power shifting and that noise is getting better. Decided to just stab it from a dead stop and everytime I did it it just fell over and died. If I roll throttle on it will smoke the **** out of them thru 1-2-3 but just a dead stop mat gives me nothing. Honestly I have never had a double pumper. I have always had vacuum secondaries to mask crap like this but I am determined to learn. I would rather not watch a bunch of Youtube videos and end up screwing up my car trying every shade trees method. I just hope someone can point me in the right direction. As far as the belt squeal I got it worked out by using a belt the local NAPA old timer recommended. Stopped it cold
Old 08-18-2022, 06:23 PM
25stevem's Avatar
Figure out a way to lock out the secondary’s on the carb, maybe with some mechanics wire or a cut off section of a coat hanger.
You want to do this so you get the primary’s to work right first.
Old 08-20-2022, 11:14 AM
ta man ta man is offline
Make sure the basics are covered. Square up the transition slot, make sure the acc pump lever is adjusted properly and proper idle mixture. Then work on your shooter size and or acc pump size.
And what carb is this???
Old 08-18-2022, 07:40 PM
bluebandit bluebandit is offline
Start here, https://www.macsautoparts.com/holley...069e429ad7a77e
Old 08-19-2022, 12:37 AM
NeighborsComplaint's Avatar
As BB said above read this:
https://www.holley.com/blog/post/acc...y_carburetors/
Your problem is all in the primary accelerator pump adjustment.
Triple Black 1971 GTO
Old 08-19-2022, 06:52 AM
Cliff R's Avatar
Cliff R Cliff R is offline
I agree with not running the engine really hard or WOT for the first few miles, but not 500-1000.
I would strongly suggest at 100-200 miles to pull the oil filter and cut it open, it will tell you IF you need to pull the engine back out or can start running it like you stole it!
There are a LOT of things to check when you have a HUGE stumble/hesitation/bog going quickly from idle to full throttle. The engine/drivetrain/vehicle specs and carb/distributor details would be helpful here......
I feel your pain with Youtube videos, I get ill trying to watch any related to carburetors especially Quadrajets. 99 percent of those folks need to shut the camera off and go as fast as they possibly can right back to their "day-jobs"!..........FWIW.......
The Following 2 Users Say Thank You to Cliff R For This Useful Post:
Old 08-19-2022, 08:45 AM
64speed's Avatar
I cut the 150 and 500 mile filter open. They were fine
Old 08-21-2022, 11:04 AM
First thing I would like to know from the OP is what the transition slot looks like? This could be the cause of the dead spot..no amount of jet changes or PV changes will help if this isn't correct. Cover the basics first.
Old 08-21-2022, 12:10 PM
JohnnyAction JohnnyAction is offline
Default Dead Spot At Idle
What ignition system are you running on your engine? If you are running a vacuum advance HEI distributor you may be having an intermittent open in the pickup coil when vacuum immediately drops when the throttle is opened. Also, along the same condition you may have a ground wire problem with the point plate if you are running a point style distributor. If you are running a vacuum advance style distributor, disconnect and plug the vacuum line and see if your condition decreases. Also make sure that your initial timing is adjusted. I would recommend 10 to 12 degrees advance as a starting point.
Old 08-19-2022, 09:22 AM
grivera's Avatar
grivera grivera is online now
What size is your fuel line and what fuel pump? Not that those will affect the idle to WOT dead spot but with 550 hp will affect your in motion high RPM performance.
Will Rivera
'64 LeMans 400/461, #16 Heads, HR 230/236, TKO600, 9inch Rear, 3.89 gears
Old 08-19-2022, 09:39 AM
64speed's Avatar
3/8 and Holley 110 GPH. If it revved any faster I would have already blown it up
Old 08-19-2022, 10:18 AM
What do you have for a carb?
Old 08-19-2022, 10:36 AM
78w72 78w72 is offline
X2. didnt this engine have FI at some point? might be confusing it with another one... is it a box stock carb or been set up for your engine?
if its a traditional holley mechanical secondary double pumper, you should be able to just remove the link bar to the secondaries, no need to conjure up a coat hanger. thats how most mech sec double pumpers ive owned or seen operate the secondaries.
Old 08-19-2022, 10:59 AM
A Holley carb or any carb is not designed to perform well when doing a "gorilla stomp" at IDLE and expect the MASS FLOW thru the engine to have the correct fuel to mix with it.
There is always a time lag with the carb circuits.
The outside air does not even really start to move into the engine and without the air and intake signal to the carb.
Then you have the air restriction thru the air filter, (You are running a air filter, right?).
If you are trying to do this "Test" what purpose does it serve if you have removed the air filter and this car is NOT A DRAG CAR. .............WOT FROM IDLE. Chee-it.
There is a thing called PHYSICS that describes how the air and fuel works in a carb.
The accelerator pumps are there to be able to do transitions from normal cruise to passing speed or
higher rpm launches to ATTEMPT to move the car across the starting line quickly.
You should have left the EFI stuff alone as the engine dying when you do that "test"
and is telling you, it is not going to work.
If you disconnect the secondary throttles and run the carb as a two barrel carb you might get the thing to NOT DIE doing your "TEST" if you put a 50cc pump on the front carb and big squirters on the primary side. But now the carb will drive like chit when on the road doing normal speed vs load transitions.
Old 08-19-2022, 12:44 PM
Weren't you EFI?? With the Sniper I could tell you why it's doing that and how to fix it. There was a discussion about that in the EFI section with good explanation as to why.
If it's a carb, I'd need to know what carb.
Knowing ignition timing helps in this scenario to some degree.
But initial thoughts are simply a lean stumble. Very common when whacking the throttle as you create a big hole and not enough fuel to fill it is the simple explanation. A new combo will take some tweaking to make perfect.
https://youtu.be/XqEydRRRwqE
Old 08-19-2022, 12:42 PM
i can "gorilla stomp" all my cars from idle with basically instant acceleration (& lots of tire smoke), there is no noticeable lag, hesitation, stumble or dying... mechanical holley double pumper with stock size acc pump on a mild built 455, using all 4's or just the primaries when i would disconnect the secondaries when i let friends drive it or to try & save gas.
same for cliff built Q-jets on a mild 400 or stroked 500+hp engine, or even a stock engine on home rebuilt qjets. maybe each engine can act different but i've never had any of those problems
The Following 2 Users Say Thank You to 78w72 For This Useful Post:
