Old 06-26-2018, 01:11 PM
tolerico tolerico is offline
Default SD455 PCV valve cover breather valley pan no hole -- PCV option
Here is the scenario:
400/461 with a valley pan that has -no- PCV provision
Stock 1967+ valve covers with drippers
Passenger valve cover with vent tube to ram air pan
Is there any other option to buying this expen$ive SD-455 reproduction oil filler cap with PCV set up?
http://www.tachrev.com/SDOilCap.htm
Old 06-26-2018, 01:23 PM
Skip Fix's Avatar
Skip Fix Skip Fix is online now
Pop a hole in the valve cover somewhere else between rocker stands and use a baffled grommet.
Skip Fix
Old 06-26-2018, 01:26 PM
Ah yes. Good call.
$10 versus $300.
