Old 03-24-2010, 02:45 AM
mr66gto mr66gto is offline
Default 66 gto stock tire size??
What is the original tire size of a 1966 Pontiac GTO?? When i turn either left or right, my tire scrapes the inside of the fenders.
Old 03-24-2010, 06:07 AM
Tim john Tim john is offline
Original size was/is F70-14 but I prefere a G70-14 for it is slightly taller and fills the wheel well much better and will not rub the heel of the fender.
Tim john---
Old 03-24-2010, 06:10 AM
Jeff Hamlin's Avatar
7.75X14 on 14X6 JK steel wheels
Old 03-24-2010, 01:32 PM
GT182's Avatar
GT182 GT182 is offline
60 series tires will rub depending on the size of them. Right now I have a set of Firestone 225/70-14s (7 inch wide rims I believe, but could be 6) on the front of mine and they don't rub. Cragar rims, not stock.... if that helps.
Gary
Get in, ShuT Up, Hang On!
"Crusin' Is Not A Crime"
Keep yer stick on the ice.
Old 03-24-2010, 01:53 PM
6704gto's Avatar
6704gto 6704gto is offline
the f70 was on 67 the 66 had 7.75x14 with 6 inch wheels
Old 03-29-2010, 10:40 AM
z06gto z06gto is offline
Default 67
the correct size for a 67 is 14 x 7 rally II's ?
z06gto
Old 03-29-2010, 11:18 AM
Dick Boneske's Avatar
Rally II's on '67 GTO's and Firebirds were all 14X6. Tire size for the '66 GTO was 7.75 X 14 and in '67 was F70 X 14 on the GTO and Firebird. I remember trading my F70 redline Wide Ovals for G70 Wide ovals when my '67 Bird was new.
The 7" rims came later.
BONESTOCK GOATS
'99 Bonneville SE Sedan
Old 03-30-2010, 01:58 PM
Default 67 Rims
JK is the correct code stamped on the rim ?
Are they dated coded as well ?
z06gto
