Old 03-10-2010, 12:02 PM
z06gto z06gto is offline
Default 66-67 Radiator codes
Does anyone have a chart on the radiator codes for 66-67 GTO ? I have several original radiators with the small metal tag with codes like "TX" and "TS".
z06gto
Old 03-10-2010, 12:37 PM
67 Lamnas's Avatar
67 Lamnas 67 Lamnas is offline
The codes are deciphered in the GM parts manuals and in the GTO restoration guide
"XE cam basher"
Old 03-10-2010, 12:54 PM
Default Codes
I did see that in the GTO restoration guide, just didn't know if that was complete, thanks.
z06gto
Old 03-10-2010, 01:18 PM
ERIC AULL ERIC AULL is offline
TS =3-4speed GTO with tri-carb or heavy duty cooling/trailering/Special axle ratio
also 67 4bbl manual HO, and Heavy duty rad. trailer, and special axle ratio
TX = 1966 automatic 389 4 bbl and tri-carb WITH airconditioner except s.wagon
Old 03-10-2010, 01:53 PM
Default codes
That's what I'm looking for, Thank you very much.
z06gto
Old 03-11-2010, 12:21 AM
RedDirtRoad RedDirtRoad is offline
ZO^GTO
can you post a photo of the tag on the radiator?
I like to see what an original radiator looks like with the tag since i am doing a concourse restoration now on my own 67
Old 03-11-2010, 09:00 AM
Default Pictures
Sure, here you go.
ID:	199819   Click image for larger version
z06gto
Old 03-11-2010, 10:11 AM
Is the BA tag on the same radiator as the TS tag?
I think the TS tag is located up by the upper rad hose? right or wrong?
where is the BA tag located?
Old 03-11-2010, 11:43 AM
Default codes
Correct, both tags came off the same radiaitor. The TS tag was located about 3" towards the center from the top hose and the BA tag was almost dead center. Both tags faced towards the engine. My TX radiaitor doesn't have any type of small tag. This is the only radiaitor I have seen with the small tag, ever.
z06gto
