Old 03-16-2010, 12:57 PM
z06gto z06gto is offline
Default Correct Z-bar for 4-speeed GTO
What is the correct Z-bar for a 66 4-speed car ?
I know the restoration guide shows one but how can you tell ?
I have two different ones and they look very similar.
Thanks,
z06gto
Old 03-16-2010, 04:59 PM
gtorich gtorich is offline
Thanks,
From what i understand if you measure the tube on a 66, end to end its 7 3/4 long
Also on a 66 the arms are both straight..........if you measure from the end to the small arm its about 2 " in
On the 67.......the length of the tube is 7 5/8.....if you measure from the end to the small arm its about 7/8 - 1"
Not that i knew any of this stuff. LOL......I got this from Ames, im in the same situation as im not sure what z-bar i had either....hope that helps some
Rich
Old 03-16-2010, 05:43 PM
Ken K Ken K is offline
I am assuming a 66 Z bar is the same as a 65. The only 67 Z bar I have is from a 6 cylinder. The pictures are 65 Z bars.
ID:	200300   Click image for larger version
ID:	200301   Click image for larger version
Old 03-16-2010, 06:16 PM
Ken, would that distance from the end to the shorter arm be 2", thats what the ames guy told me.
Rich
Old 03-16-2010, 06:22 PM
Ok, this might be easier, is this a 66 or 67 Z bar.
Old 03-16-2010, 06:57 PM
John Milner's Avatar
John Milner John Milner is online now
It was my understanding that a 65 Z bar was a bit different than a 66 in that the arm for the lower clutch push rod is a bit closer to the block. I could be wrong on that, though.
Old 03-16-2010, 09:04 PM
This is as close as I can get a camera on a 65.
Old 03-17-2010, 06:14 AM
Jeff Hamlin's Avatar
Grease fitting was added in 67' no fitting on 66' Z
Old 03-17-2010, 08:23 AM
Default Z-Bars
Look at these pictures, is this correct ?
Both have grease fittings.
z06gto
Old 03-17-2010, 08:25 AM
Default 66
66 picture.
z06gto
Old 03-17-2010, 08:27 AM
Default 67
67 picture
z06gto
Old 03-17-2010, 10:56 AM
66 picture.
Z-06........mine looks like the one you have in the pic for a 66.......about 2" in from the end to the shorter arm.
I take it on the pic of the 67 bar.....its about an 1" in from the end to the shorter arm.
Thats the way they are from ames.............well at least thats what they told me when i had the guy measure the two for me.
From the pic, looks like a slight curve on the longer arm on a 67...............looks like the 66 long arm is straight.
Thanks for the pics, helps my situation out.
Rich
Old 03-17-2010, 11:24 AM
Rugratman's Avatar
Rugratman Rugratman is offline
67 z bar pic
........I'm just learning as I go.......
Old 03-17-2010, 11:33 AM
The difference in the 67 Z bar may be do to the avalabilty of the better exhaust manifolds. The engine will sit in the frame the same on a 67 as it will on a 65 or 66. They all use the same bellhousing.
Old 03-17-2010, 11:49 AM
Rugratman's Avatar
The pedal set up in the car is different, as the steering column is also different. I would think the connecting points would have to be different also.
Old 03-17-2010, 11:58 AM
The pedals and steering columns can be swapped around if you have the right parts. The rod that connects the Z bar to the brake pedal is different on a 67, there is also a welded on bracket on the 67 clutch pedal where the rod connects to. It's different on earlier cars.
Old 03-17-2010, 12:06 PM
67 clutch pedal and rod. The rod is on the wrong side of the bracket.
Old 03-17-2010, 12:09 PM
65 clutch pedal.
Old 03-17-2010, 05:46 PM
ponderopa66's Avatar
ponderopa66 ponderopa66 is offline
Here is the 66 Z bar I bought recently from Ames. Note the grease fitting. Stay tuned; I have a 66 GTO and a 67 400 engine...
ponderopa66
Old 03-17-2010, 05:48 PM
Once more with pic!
ponderopa66
