Old 08-13-2012, 09:51 PM
Steve Barcak's Avatar
The ones I use I just built/midified them from what I could find in my yard or another yard. A little fab skills, it is not rocket science.
Hundreds of Pontiacs in Az
Facebook- Pontiac Heaven
Hosting-
Phil 2:11
Old 08-14-2012, 11:21 AM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
Maybe I can sell mine for $100 each!
Skip Fix
Old 08-14-2012, 11:42 AM
harry k's Avatar
harry k harry k is offline
Send a message via AIM to harry k Send a message via MSN to harry k Send a message via Yahoo to harry k
yeah if you find the number matching guy wants it & don't forget my cut
like i said earlier TCI bracket is copy of the GM ....
someone who thinks logically is a nice contrast to the real world.
http://www.youtube.com/watch?v=3FfKVVZW1-Y
Old 08-18-2012, 11:27 PM
scld1354's Avatar
scld1354 scld1354 is offline
Originally Posted by Skip Fix View Post
I bought about 2-3 of those I have on a shelf new from GM as they are for a 200 and a Qjet.
Can you measure from the centerline of the carb mounting bolt hole to the TV cable mounting plane? That way I can cut down the bracket I have.
Originally Posted by lust4speed View Post
Welcome to the broken nipple club - I'm a charter member.
Old 08-22-2012, 11:17 AM
Skip Fix's Avatar
2.060 for the center to the TV cable hole to the center of the closest carb stud. Hard to measure between stud holes as the bracket isn't solid there.
Skip Fix
Old 03-04-2013, 08:43 PM
scld1354's Avatar
Default Update
Got the Q-jet rebuilt and set on top of the motor today. I found a bracket identicle to the one pictured below.
Ben stated the bracket will make it easy. But the brakcet hits the #5 runner. I dont mind cutting and welding the bracket, but before I do, I just want to make sure I am not missing something. Like, if I could just bolt it on if I want to use an inch of spacers between the carb and the bracket. Has anyone else had this issue?
Jon
Old 03-04-2013, 09:19 PM
FrankieT/A's Avatar
Last one I used came off late eighties Cadillac with 307 Olds and Qjet. The bracket looks like the one pictured, bolts to rear carb bolts/studs. I bought the carb also and switched the shaft to my carb. No measurements, no angles, no question! All cost $25.00 from jy.
Old 03-05-2013, 12:46 AM
scld1354's Avatar
Frankie, what intake are you running? I wouldn't think it would make a difference, but Im running a 70 iron intake. I used a chevy primary shaft (so the linkage would fit the TV cable) when I rebuilt the carb.
This is the area I am having trouble with......
Old 03-05-2013, 08:02 AM
max 93 max 93 is offline
I ground that lug off the intake and a little gringing on the bracket and it works fine
Old 03-05-2013, 08:34 AM
projectfolly projectfolly is offline
Jon
I had the same observations on my set up using the Olds 307 bracket and a cast iron intake - the bracket hit the intake runner, right at the rectangular boss on the top of the runner.
I ended up doing one thing at a time to kind of sneak up on the clearance needed:
Shaved a little off the bottom of the bracket where the contact point was.
Shaved a little off the intake runner boss.
Used the thickest carb gasket I could find.
I used studs for the rear carb attachment so I could play with spacers and raise the bracket up a little off the carb to clear the intake runner.
All the aforementioned got the clearance needed between the bracket, but how to hook it up the TV cable to my Q-jet which is a late 70s 400 unit?
Solved that with an adapter from Art Carr (and others sell) which bolts onto the throttle arm. It has the correct stud for the TV cable.
After everything was bolted up, I checked the geometry and all seemed well.
However, once I tried to add the vacuum fitting to the rear of the carb, the fitting hit the bracket. Fortunately this was easily resolved with a little grinding on the bracket for clearance.
I can post pics if you like.
Old 03-05-2013, 08:15 PM
FrankieT/A's Avatar
I used that set up on a '61 Cadillac with a '72 472. I just used a 1 inch spacer. The Cadillac intake is very flat and I had the opposite problem. How much interference are you having? I would think if it were only like a quarter of an inch, bending the bracket up would not effect the geometry enough to cause a problem. You're supposed to measure the valve in trans anyway.
Old 03-14-2013, 02:25 PM
scld1354's Avatar
The only information I can find is about the carb end (measurements, diagrams, etc.). Can you tell me more about measuring the valve?
Old 03-14-2013, 08:09 PM
FrankieT/A's Avatar
Please read all this, it's very informative
www.tvmadeez.com/article/index.php
