Old 10-07-2022, 03:37 PM
Nacs Fab's Avatar
Nacs Fab Nacs Fab is offline
Default Stefs 1240 Pan in First Gen Firebird
I’m planning on modifying my front stub to fit a Pontiac V8 In its stock location fore and aft. I am going to cut both of the stock crossmembers out and install 4130 Plate and 1-5/8” tube just inside of the factory control arm attachment points. I am installing a mustang rack so I have to install the mounts for it in one of the horizontal tubes that I will install. Of course, before cutting the subframe I’ll be adding some substantial bracing to keep it square as it was (not very). Yes I know camber is off, playing around with upper ball joints and haven’t used any shims. I’ll probably cut my own one-piece shims on my CNC machine.
Anyone modified their crossmembers and have photos of how much you took out?
I need clearance for a Stefs 1240 pan. Just wanted to get some dialogue going before I start fabrication. I’m using All Pontiac 3/16” steel front and mid plates and a Innovative Racecraft Chromoly TH400 Trans Crossmember with a Poly mount on the trans.
Also anyone have a trashed 1240 Stefs I could use for mock up?
Old 10-07-2022, 04:52 PM
Scott Stoneburg's Avatar
What I did to mine.
Name:	misc pictures (18).jpg
The Following User Says Thank You to Scott Stoneburg For This Useful Post:
Old 10-09-2022, 12:00 AM
Mean Green's Avatar
Mean Green Mean Green is offline
74 GTO, same subframe
www.lancablingsolutions.com
Old 10-10-2022, 06:50 PM
RAIV-Z's Avatar
RAIV-Z RAIV-Z is offline
69 Firebird Subframe.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
Old 10-10-2022, 09:56 PM
slowbird's Avatar
slowbird slowbird is offline
Curious how long it takes to get one of these pans now days?
Old 10-11-2022, 02:37 AM
Dragncar Dragncar is offline
I got mine in about 6 weeks and that was well after Covid started messing things up. Called Canton first but they could not make me a race pan at all due to Covid.
They guy who built them was out.
Old 10-11-2022, 12:38 PM
Dave Polichena's Avatar
Dave Polichena Dave Polichena is offline
Mine was similar to this, added tabs so I could unbolt to remove pan in car.
Honestly don't even think I needed it, bolts slid in and out easily on the ground or on the lift.
Dave Polichena
Old 10-11-2022, 07:40 PM
aaronman aaronman is offline
68 bird fabrication. Oil pan is removable.
Old 10-12-2022, 11:59 AM
Mean Green's Avatar
I have a bolt in 1 5/8 bar for mine too. I've had it in and out 10 times. It slips in and out the same as it did the first time.
I keep it bolted in, but it's probably not necessary.
Old 10-12-2022, 09:20 PM
Jromaine87 Jromaine87 is offline
Just called today. There 6-8 weeks out. I have one that had a rod threw it and was repaired. Want to sell it so I can buy a new one!
Old 10-12-2022, 09:21 PM
I have one that had a rod threw it but is fixed. Plan on selling it.
Old 10-12-2022, 09:23 PM
I have one as well, would be removable if I didn’t have to use so much gasket sealer! Haha
Also, what kind of socket did you use to put in the 4 recessed nuts. I had to use a belt sander and grind my socket down to almost nothing!
Old 10-13-2022, 12:35 AM
Nacs Fab's Avatar
I messaged you about it. What’s your price?
Old 10-13-2022, 01:13 AM
If you are talking about the ones under the plugs on the kickout side it takes a 1/4" drive set with long extension. 3/8 allen socket would not fit.
I had The Right Stuff all over and the 3/8" set would not fit. I had to scurry around and dig out 1/4" stuff before it dried.
Had a crank scrapper in there too. Would have been a mess if I had to disassemble and re do.
Old 10-13-2022, 09:24 AM
I would take $400 for it.
