What is this part?
I have a 69 bird that is being restored. I am taking out the wiring harness to replace and came across this under the dash. No wires were hooked to it and it was screwed to the clutch/brake pedal assembly. the clutch or brake did not contact it. The lever on the left is spring loaded. When you put an ohm meter across the 2 pins the switch is open and closes when you push against the spring.
The car has a V8 with a manual when I got it. Not sure if original to the car as I have found many 67 firebird parts installed. Thanks in advance |
manual trans safety switch on the clutch pedal..
Mark.. The Goat whisperer "I spent a lot of my money on booze, crazy women, and fast cars. The rest I just squandered." |
Hmmm, Is that the same as a nuetral safety switch? I have a 1/2 round ring looking thing as well that wires are going to.
Yes clutch must be pushed in for car to start---BOB
half round thing...
Is the sensor for the reverse lights. Has to be hooked up with the backdrive linkage to work.
Bill
'69 'Bird 'vert. An all Pontiac T/A lookalike and a work in process. 99% done Bill Jacobs |
