Old 10-08-2019, 10:41 AM
DarcyL DarcyL is offline
Default stock 455 crankshaft bobweight spec
Hey- just wondering if anyone knew off hand what the crank bobweight value was for a stock 455 crank- Eagle lists their stock cast 455 crank bobweight at 2280 gm., but I would imagine that is targeting forged rods, and light forged pistons as in their rotating assemblies- Thanks,
Darcy
Old 10-08-2019, 11:03 AM
Steve C. Steve C. is offline
I have no clue. Curious, does the material make a slight difference. Armasteel or nodular iron casting. In an attempt to shed engine weight and improve fuel economy during the mid 1970s, Pontiac lightened its V-8 crankshaft of the era as well. The casting isn’t quite as robust as earlier examples.
https://www.pontiacdiy.com/pontiac-v...ormance-guide/
The obvious, since different rods and different pistons are different weights, it is impossible to make a crankshaft that is balanced "right out of the box" for any rod and piston combination.
All crankshafts must be balanced to your specific rod and piston combination.
Old information here:
Old 10-08-2019, 07:45 PM
AG's Avatar
AG AG is offline
The one I built this year with Eagle rods and Icon forged pistons with a stock 455 crank was 2190.6 g.
Old 10-08-2019, 08:20 PM
'70 455 crank
6.625 Carrillo steel rods
Custom 4.181 JE pistons
2216.4 bob weight
Old 10-08-2019, 08:30 PM
AIR RAM AIR RAM is offline
This is not a stock crank however for reference, the engine I'm building right now shows my bobweight with a 4.5 Scat crank/6.7 H-Beam's and Carillo Pistons has the bobweight @ 2181
I have a 455 crank for sale if interested. Its at the machine shop getting cleaned up... so I will have details once I get it back.
SPEED SAFE, NICK
"The grass is not greener on the other side, its just fertilized with different $h!t"
Old 02-21-2023, 09:54 PM
65sport 65sport is offline
SPEED SAFE, NICK
I know it's an old post but I'm curious.
Is the 2181 what it was adjusted to, or what is was before balancing ?
